Closed Thread
Old 05-03-2007, 07:29 PM
Default ID Tracker II - Version 1.14.0
- Added a "Time Window Search" to the audio playback screen.
I have not updated the help file yet because I am debating on the final form this function will take. I wanted to get it out there for people to play with over the weekend and possibly provide feedback.
Basically, the function allows you to search for recorded audio during a specified time window. You enter the date, time and the amount of time before and after the specified time to search. If any entries are found, you can then use the left and right arrows to move through and play the selected segments.
The reason I came up with this is because when attempting to identify new talkgroups I would hear something like "go to TAC". I then I would have to search through all the other unidentified groups to see if I could find the "TAC" channel. This new functionally allows me to quickly search through those groups that occured within the same time frame.
ID Tracker Mirror: http://209.240.24.87/idtmirror/IDTracker.htm
David M. Hitchner - K5DMH
Baton Rouge, LA
Baton Rouge Area Scanning: http://bellsouthpwp.net/k/d/kd5eis
ID Tracker/ID Tracker II: http://bellsouthpwp.net/k/d/kd5eis/i.../IDTracker.htm
Closed Thread
Similar Threads
ID Tracker II - Version 1.13.2 brscanning Scanner Programming Software 0 04-27-2007 04:27 PM
ID Tracker II - Version 1.13.0 brscanning Scanner Programming Software 5 04-14-2007 05:54 PM
ID Tracker II - Version 1.10.0 brscanning Scanner Programming Software 54 04-02-2007 12:09 PM
ID Tracker II - Version 1.9.0 and Web Import Add-In brscanning Scanner Programming Software 9 01-27-2007 11:38 PM
ID Tracker II - Version 1.7.0 - Just in time for the weekend. brscanning Scanner Programming Software 21 01-27-2007 04:21 PM
