Old 05-04-2007, 04:59 PM
Default PCI serial / parallel card reccommendations
I purchased a new computer recently which obviously lacks either a parallel or a serial port. I do have a few older printers that I have been using over parallel, and serial for a few scanners, my 7800, as well as knowing its there when I need it for other common place applications.
I do know that there seems to be the good and bad of the USB adapters as far as what they seem to work with. Does anyone have any recommendations on brands for either USB or PCI adapters? Has anyone used a PCI serial / parallel card for programming?
Thanks.
Chad Rust
KD8AYM
rustchad@msu.edu
Pro-2049 / Pro-94 / Pro-99 / BC895XLT / BCT-15
Yaesu 7800 / Yaesu 8800 / Yaesu FT-60R
Old 05-04-2007, 05:46 PM
madnachos's Avatar
I have a small PC setup with two dual serial port PCI cards so I have 4 usable serial ports for scanner operation and programming. You can pick them up from newegg.com for about $10...search for 'RC-301'.
Uniden BCT15 / BR330T / Pro-96 / Pro-97 / Pro-95 / Pro-2051 / Kaito KA2100
Old 05-04-2007, 06:56 PM
GreatLakes's Avatar
You might want to confirm that the supplied drivers are VISTA compatible, or that the manufacture can supply them, in the event that your new computer runs VISTA, or you intend to in the future.
Old 05-04-2007, 08:55 PM
Yeah the first ones I had looked at were the SIIG I believe because it has 1 Parallel and 1 Serial and only takes up 1 slot. As many of you have mentioned that the Rosewell's have worked well then I might just have to use up the last two with something like this
http://www.newegg.com/Product/Produc...82E16815166006
Anyone used the RC-303 before? The reviews sound good for printing which is probably all I would use the parallel for. The website also shows drivers for vista.
Chad Rust
KD8AYM
rustchad@msu.edu
Similar Threads
Mississauga/Caledon Fire Pager? Chrome69 Eastern Canada Radio Discussion Forum 113 02-09-2007 01:37 PM
Finally, WiNRADiO on a PCI Card, soon! MacombMonitor All Other Receivers 9 06-05-2006 12:08 PM
PCMCIA Serial card w0sd Trunking Control Channel Decoding 3 08-24-2005 05:49 PM
Computer control cable gg750 Uniden Scanners 20 08-15-2005 07:47 PM
Parallel to Serial or USB to Serial pelicans Uniden Scanners 7 05-20-2005 01:49 AM
