Old 09-23-2007, 08:14 AM
Tryton's Avatar
Default ARC996 Saving problem!
Well I tried the demo and liked what I saw.. So I purached the full version. I imported the 3 systems I had via there uasd files. ok I worked them, fixed them up, even saved them.. After that I bought the program, and entered the key.. Great its unlocked.. now, every time I try to exit out and is asks to auto save, I click yes then it keeps giving me the same 2 errors one right after the other! I have to ctrl-alt-del just to get out! I deleted all the systems out, cleared the temp files.. and it still does it!!! HELP!!! I'm attaching the screen captures..
Equipment : Uniden Bearcat BCD996XT
________________________________
K1SPL
Old 09-23-2007, 09:23 AM
I have never had that problem before but I did have problem with VISTA and that program!
I had to set the Baud rate to the lowest settings on the computer and on the scanner other wise I got lots of error messages!!! and I also had to use Control ALT: Delete.
Good luck.
Old 09-23-2007, 09:52 AM
Dubbin's Avatar
Shoot an email to Gommert at Butel and and he will fix you right up.
Dwayne
My Scanner Feed
Old 09-23-2007, 10:40 AM
mike_s104's Avatar
Good luck.
32 bit or 64 bit Vista? I kept getting loop time out errors with programming. I'm also having issues with the Virtual control and the video. I'm pretty sure it's the virtual control since it only happens when I'm running it.
I'll post the issue here when I can get a picture and email Gommert. He's promised an upgrade this year for ARC996, but I'm not really holding my breathe. His instructions for Vista don't really apply since I have full admin rights to the profile I'm using.
Old 09-23-2007, 12:58 PM
Tryton's Avatar
ok, i figured it out. I had to go into the program property's and check "Run as administrator" now it works flawlessly!.. Vista sucks A$$!!!!!!!!!!
K1SPL
Old 09-23-2007, 01:16 PM
mike_s104's Avatar
I don't think it sucks, there's just a learning curve and incompatible software. :-)
Old 09-24-2007, 03:28 AM
datainmotion's Avatar
I have had the same problem on rare occasions and I run XP Pro with Admin privileges (although it doesn't lock up). As soon as I remember the exact circumstances I'll post them. By that time Gommert will probably have replied.
Denver International Airport - Public Safety Online Scanner
Travelling to or through Colorado? Click here
Old 09-24-2007, 09:04 AM
Butelsoftware's Avatar
Send a message via Skype™ to Butelsoftware
The error indicates the software could not save the file, there are several reasons why this error is shown, in this case Vista blocked access to the default application folder. Under Vista ARC996 must be run with administrative rights.
Gommert
www.butelsoftware.com
http://www.butelsoftware.com
Become a BuTel Software affiliate! Check our website for details.
US Sales: 1-800-SCANNER http://www.scannermaster.com/?Click=41054
Old 11-28-2007, 08:28 AM
Default Running XP
And still have the problem, the whole thing locks up, can't get it to save or do anything......I have administor rights, can't figure it out.....not a happy camper.....
Craig
ccclifton@sbcglobal.net
San Jose, CA
Similar Threads
Edacs / Motorola Digital Problem 800crazy1 Uniden Scanners 14 03-22-2006 07:05 PM
Pro-83 And VHF-Hi problem bviator Radio Shack Scanners 9 03-20-2006 06:29 PM
Pro-79 Problem y10kiscoming Radio Shack Scanners 3 06-17-2005 11:06 AM
Motorola Type II Scanning Problem w/ Pro-92 and 2067 TKennedy1975 Radio Shack Scanners 4 05-27-2005 09:44 AM
BC898T TV CH 8 Problem N9WP Uniden Scanners 4 11-30-2004 08:05 AM
