Old 09-30-2007, 07:54 PM
NYRHKY94's Avatar
Exclamation Virtual Control Disappeared on ARC898?
I've been using ARC898 for several days now and everything was fine until today. The virtual control just stopped working all of a sudden? When I click on the virtual control icon, nothing appears on my screen. You can see virtual control sitting in the task bar, but it won't come up anymore. I even tried uninstalling and starting over but that did not resolve the issue.
I've sent Butel (Gommert) am e-mail but wanted to see if anyine else has experienced this or have any ideas why it just stopped working?
P.S. I've checked the serial cable and it's fine. I tested it with Scan Cantrol and that works fine (can see the frequencies & tags on the PC).
Help please!
Thanks - Mike
Old 09-30-2007, 10:28 PM
mike_s104's Avatar
Help please!
Thanks - Mike
have you tried right-clicking on the app running in the task bar? there may be an option for "restore" you can try.
also, what OS are you using?
Old 10-03-2007, 09:25 AM
NYRHKY94's Avatar
Problem solved. Under software setup/virtual control, all I had to do was un-check store virtual control window position. Once I did that, the virtual control was visable again.
I like using that feature for my streamwebtown feed because I use the screen capture option. I have re-checked that box and all seems well again. It must have gotten into a funky state, but it's working fine now.
Thanks!
Old 10-03-2007, 06:51 PM
mike_s104's Avatar
cool...glad you figured it out.
Similar Threads
MPT1327 Sites in SE Queensland ThePhantom Australia Radio Discussion Forums 3 07-24-2006 02:48 AM
ARC396 Virtual Control KT4HX Uniden Scanners 21 02-16-2006 09:23 AM
Free BC246T Advanced Virtual Control Software brianfoy Uniden Scanners 14 02-08-2006 01:31 AM
Virtual control of BC246T: A silly question daledrums Uniden Scanners 11 11-13-2005 01:26 AM
Free BCD396T Advanced Virtual Control Software brianfoy Uniden Scanners 12 07-27-2005 07:22 PM
