Old 10-08-2007, 02:37 PM
Default win95 can't see channels below 34
Is there a way to scroll down past this to see to channell 100, I don't see a scroll bar, and when I scroll, it doesn't move everything up to see where you are at.
Old 10-08-2007, 03:31 PM
loumaag's Avatar
Moderator
How many you see is all dependent on your screen resolution and the size you have the window. However, that has nothing to do with scrolling. There is indeed a slider to the right of the frequencies, just as there is one to the right of the TG area for the purpose of scrolling each grid. Just as a side note that would be channel 99; the channels are numbered 0 - 99 on each bank.
Lou Maag
Rules and Guidelines for Forum Post Content
Old 10-08-2007, 04:18 PM
It works fine when i open it and it isn't maximized, but once i maximize it, I loose the bottom slider, will make sure not to do that.
Old 10-08-2007, 04:56 PM
loumaag's Avatar
Moderator
You initial (unedited) reply seemed to indicate that you still could not see the slider for the channels. As for the bottom slider, it only appears if you shrink the window so that not all the fields can be seen. The sliders I am referring to I have outlined in red below:
Lou Maag
Old 10-08-2007, 05:36 PM
thanks, I had to make the boxes wider to get the scroll bars, when I got out and back in they were there along with the being able to go all the way to the bottom.
Similar Threads
Icom R1500 Review tanger32au ICOM Receivers 4 06-12-2007 03:11 PM
System configuration by only system id nonposter Uniden Scanners 25 02-20-2007 12:15 PM
Viper on the 11pm news, WBTV 3 Charlotte Grog North Carolina Radio Discussion Forum 16 03-22-2006 07:31 AM
785D 1000 channels here, 1100 channels there? safetyobc Uniden Scanners 1 02-02-2005 08:50 PM
Win95 & Win96 zip files for Santa Clara City,County & norm25 San Francisco Bay Area Discussion 6 01-19-2005 06:00 AM
