Old 10-08-2007, 08:54 PM
KG4LJF's Avatar
Send a message via AIM to KG4LJF Send a message via MSN to KG4LJF Send a message via Yahoo to KG4LJF
Default ARC396 Vista Drivers????
Anyone have any word on the ARC Vista drivers?
Realistic Pro-57 (10 channel workhorse)
GRE PSR-500
Old 10-08-2007, 08:56 PM
brandon's Avatar
ARC396 should work with Vista. Just make sure you run as "Admin" (right click icon, go to properties and select to always run as administrator) if it gives you fits. Another tip is to install in a separate folder than C:\Program Files, put it into C:\Butel or something. Installing under the "Program Files" directory under Vista doesn't behave well with some older programs.
Old 10-08-2007, 09:25 PM
KC9GLG's Avatar
ARC396 works fine on my Vista laptop computer.
Old 10-09-2007, 11:50 AM
mike_s104's Avatar
just follow the directions on the Butel site and they work fine OR just make sure the account you are using has administrator rights.
are you having trouble with a USB-Serial adapter driver instead?
Old 10-09-2007, 05:02 PM
KG4LJF's Avatar
Yeah it's the USB cable I need a driver for.
GRE PSR-500
Old 10-09-2007, 05:53 PM
mike_s104's Avatar
try the manufacture first...
if it's a Prolific chip, they do not make drivers for Vista. see: http://www.prolific.com.tw/eng/downloads.asp?ID=31
I did find some for that chipset, but not sure if they work...
http://www.trendnet.com/asp/download...=571&SUBMIT=Go
If you're running Vista 64bit, just give up and get this adapter or one with a FTDI chip (what I did):
http://www.usbmax.com/USBG-232MM_USB...XP_Systems.cfm
they sell a 12" as well. www.usbmax.com, www.usbgear.com, www.serialgear.com ect are all the same, only the shipping is different. I got mine from www.usbmax.com but the drivers CD has www.usbgear.com on it. it works great though.
Similar Threads
Vista Drivers jambo Radio Shack Scanners 2 09-29-2007 01:33 AM
Are Vista drivers due soon for 396T? kinekep Uniden Scanners 4 08-14-2007 03:42 PM
Uniden USB-1 cable, ARC396, & Drivers? KG4LJF Scanner Programming Software 29 07-08-2007 06:04 PM
USB-1 XP drivers with 32-bit Vista? cj57548 Uniden Scanners 1 06-08-2007 04:34 PM
ARC396 and scanner configuration Jon_Hanson Scanner Programming Software 1 04-09-2007 02:10 PM
