| Scanner Programming Software This is the place to discuss scanner programming and control software. |
10-13-2007, 12:01 AM
Program Pro 97
Hello, I've been on this forum for a little while now and i have read hours on how to program the pro 97 scanner and the trucked channels and talk groups and all the fancy jive. Anyway i have had my scanner for a while now and when i first got it i was trying like hell to get it programed, i got win 97 read all about that how to work it and what not, all the cables. Long story short i never got any where i wanted, to put in police where i live, but nothing. So i put my pro 97 on my desk and didn't really do anything with it for months well i decided to try again today after blowing of the inch of dust and i just got done "trying" to program some stuff but nothing. Can someone PLEASE help me, i've read for hours on end and i still am TOTALLY lost with how to program this thing. When i use win 97 and load to my scanner it says it loaded but when i go in my scanner it's all the crap that comes pre-programed. Anyway can some one tell me if i'm missing a step i am seriously am going crazy and this is driving me NUTS
10-13-2007, 12:11 AM
What system are you trying to monitor ? with win97 and a premium subscription to RR programming should be a snap. someone here can help but more info is needed.
10-13-2007, 12:14 AM
Where do you live and what do you want to listen to. The Database and the software might be able to just about do it all for you.
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
Grundig Satellit 700
10-13-2007, 02:06 PM
Question also
I also have a question.. I am trying to program my pro-97 with frequencies for Charlotte/Mecklenburg County, NC. I am unsure how to use the database. I was able to download a .csv version of the file -- but win97 was unable to import it. Any ideas/suggestions? Thanks!
10-13-2007, 02:11 PM
Try File>Web Import from within Win97.
10-13-2007, 02:52 PM
Moderator
See this sticky right here in this forum.
10-13-2007, 03:01 PM
Charlotte / Mecklenburg County is a large system so it needs to be broken up
Check out this p97 file and see how I broke it up
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
10-13-2007, 06:43 PM
Well since at the moment i'm totally lost i just want to start with the closest and easiest thing which would be my local police, which is Pleasanton, California all there stuff is trucked i cant remember what system that they use.
10-13-2007, 07:44 PM
I guess this is what you want to start with, http://www.radioreference.com/module...ame=RR&sid=350 get your feet wet with this p97 and learn from here.
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
10-13-2007, 10:10 PM
So do i just enter the frequency or do i enter the DEC/HEX? Because i'm getting the hang of the frequency enter i just can never keep track of them and what is the extra step to take when dealing with a trucked system?
10-13-2007, 10:22 PM
Well you could simply use the file I posted here. Getting the Talk Groups in with Alpha Tags is much easier if you use the Win97 ability to grab the programming directly like I did.
You have to program in the frequencies with the set to MOT, then use PGM T and the arrow keys to enter each TG ID. It's much easier with the p97 file
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
10-13-2007, 10:26 PM
AHHHHH there is smoke coming out of my ears, not again this the is same thing that happen when i was reading the manual, what you typed is looking like English but when i go to try to do anything it turns into Chinese and have no clue what to do. I am truly starting to think i cant get this
10-13-2007, 10:36 PM
Don't try to do it manually let Win97 do it just use the file I posted
http://www.radioreference.com/forums...1&d=1192318977
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
10-13-2007, 11:29 PM
Ok cool so i uploaded it my scanner, now how do i access it on my scanner? When i turn it on will it automatically pick up on the loaded data and scan the frequency's?
10-13-2007, 11:34 PM
Yes if it uploaded correctly just press scan.Actually it should begin when you turn it on. If you press the M it should lock onto the control channel press Scan to go back to scanning.
You should also see L-P Public Safet and Conventional alternating on the bottom line of the display.
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
10-13-2007, 11:42 PM
Ok so i think i'm going in the right direction, so i uploaded the file to 97 but the file is setup to be bank one but my scanner only scans bank 1 and 8 and if i get rid of those two it says all the others are locked out, did i miss a step?
10-13-2007, 11:46 PM
Doesn't sound like it uploaded it should erase everything programmed into the scanner except the new upload.
The p97 has it set up in banks 0 and 1 O is L-P Public Safet 1 is Conventional and only has one frequency.
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
10-13-2007, 11:48 PM
How long does it usually take to upload when i plug it in and hit upload it start and say writing data and then about a minute maybe a hair more it says done and the box goes away, now just a foot note my scanner say CLONE MODE when i am uploading is that wrong?
10-13-2007, 11:51 PM
It ill say Clone Mode when you plug the cable in, then when it uploads you should see black bars filling in on the display.
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
10-14-2007, 12:02 AM
O this is good to know, so the clone mode is good but when it uploads there isn't any black bars, ill have to check the comm port. But its safe to say that i am on the right road when it uploads and black bars are on the screen?
