Old 10-23-2007, 10:15 PM
Send a message via Yahoo to rafale01010
Question 20-289 and pro 96
who has the drivers for the serial cable 20-289?
RS Pro-96, RS Pro-164, RS Pro-137, Regency R1070, Uniden BC350C, Uniden BCT12 Stormtracker, McDonald CE-110, Uniden PC78XL
HCFD Station 5 Explorer Post 200 Exp 15, the Lakes Fire Department
Old 10-23-2007, 10:42 PM
hoser147's Avatar
Smile
Radio Shack and there are other software programs such as win96 By Don Starr @ Starrsoft Hope this helps Hoser
Good Scanning Hser
http://www.radioreference.com/apps/audio/?feedId=165
Old 10-24-2007, 01:22 AM
loumaag's Avatar
Moderator
The serial cable does not require drivers, it is a serial cable. A USB cable requires drivers so that it can be a serial cable. All USB devices require drivers, no serial cable requires them.
Lou Maag
Rules and Guidelines for Forum Post Content
Old 10-24-2007, 05:23 PM
Question finding it
thanx but scansoft plus lite cant find the scanner.how do need to "find" it?
Old 10-24-2007, 05:44 PM
loumaag's Avatar
Moderator
I am guessing you mean ScanCatLite Plus, not ScanSoft (which is optical scanner software); I will not discuss what your software pitfalls are, they are well documented (especially in regard to a Pro-96/2096). However, most times when any software has trouble communicating with a scanner it is because the COM port has been captured by some other piece of software even though you may not think you are running it; big problems are usually software linked to PDA's (Palm's, etc.). Make sure that your COM port has not been captured by some other resident piece of software and try again.
Do yourself a favor and buy Win96 for your Pro-96 programming.
Lou Maag
Old 10-24-2007, 05:49 PM
Default win96
yeah i meant scancat plus lite.i just downloaded the win96 demo and will try to program the scanner. does the scanner have to be on to program it or does it matter?im new at the vscanner part of programming.
Old 10-24-2007, 06:04 PM
loumaag's Avatar
Moderator
The radio has to be on to either upload or download, but in no programming software package that I am aware of does the radio have to be on (or connected) to program on the computer. Remember, Win96 may well run into the same problem with the Port as ScanCatLite; I mean the one thing that SCL can do is communicate with the radio, I just don't think it sends or reads the right stuff when dealing with a Pro-96.
V-Folders on the Pro-96 are no different than any other programming on the radio, the radio is just able to store those 10 (11 really) extra "set-ups" so you can access them and swap out the main memory from the keypad.
Lou Maag
Old 10-24-2007, 11:16 PM
Default ??
i got it working with win96, but now on my trunked channels(control channels) id normally have id codes coming up. now i have nothing and hear just static. did the program do something?i even swiped the memory with a factory default and redid some by hand and am still getting nothing on the trunked frequencies.
Old 10-25-2007, 09:54 AM
loumaag's Avatar
Moderator
Just make sure that both each frequency assigned to the trunk system is appropriately marked (MO or ED) and that the bank itself is in the correct mode (MOT or ED). Either one not set will result in the situation you are describing.
Lou Maag
Old 10-25-2007, 03:19 PM
Default ok
i made sure of that both the frequency an bank is motorola.go figure it does that when i get something new.
Old 10-25-2007, 03:45 PM
loumaag's Avatar
Moderator
Post the ".p96" file that has the set-up here; zip it or add ".txt" to the end so you can upload it. Tell us what bank the system is in and maybe we can figure it out for you.
Lou Maag
Old 10-25-2007, 04:43 PM
Smile Thanx
never mind got it back 2 working.thanx 4 ur help
