Old 10-26-2007, 09:39 PM
Unhappy Uniden BC898T SS not workung
I have a new Uniden BC898T and paid for the BC898T SS software. I does NOT work. I have contacted Uniden support to no avail. The last thing I was told is that since I use Windows Vista that may be the problem. I have verified my Port 3 & 9600 speed. Has anyone had this problem and found a resolution?
Thank you.
Bob in KY. topcat@vettenut.com
Old 10-26-2007, 11:16 PM
Caesar's Avatar
Send a message via ICQ to Caesar Send a message via AIM to Caesar
Thank you.
I am sure you are doing this right but just to be sure, you do have REMOTE turned on correct? and the proper speed set on the radio also? are you using a serial cable on both ends or is one end have a usb adapter to go into the pc?
Uniden: BCD396T, BR330T & BCT-15 (x3)
Icom: IC-91AD & ID-800H (D-Star)
Yaesu:FT-857D
Radio Shack: Pro-163 & Pro-197
Heathkit: HA-10 (1KW Amplifier)
DV Dongle
Old 10-27-2007, 08:14 AM
Wiki Admin
It wouldn't surprise me at all that Vista is the issue. I've seen some reports - and I'm not sure this is exactly the issue, but it's a common enough problem - that you need to install the software with admin rights, not as a user. Install as a user and some software simply won't work.
Besides, I'm willing to be ARC898 and Scan Control work much better than the SS software any day.....73s Mike
Old 10-28-2007, 11:08 AM
Unhappy I downloaded it
And after I installed it I tried to read from the scanner. Scanner not foung message came up. The scanner wis on, went to remote and verified COM3 & 9600 BPS, then tried again - same thing. Then tried auto detect - Same thing. I have no idea. Maye the demo version should be upgraded to the full version?
Bob in KY.
topcat@vettenut.com
Old 10-28-2007, 11:18 AM
n2mdk's Avatar
Did you confirm the Com Port number in the Windows Device Manager.
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
Grundig Satellit 700
Old 10-28-2007, 02:35 PM
Unhappy
Yes, I did. COM 3 @ 9600 BPS
Old 11-03-2007, 04:09 PM
Wink It is working now!
It turned out that I had to replace a serial cable and now all is working. Thanks to all who offered suggestions. Bob
Similar Threads
Best vendor for BCD396T? ndparts Uniden Scanners 50 07-17-2008 09:51 PM
Uniden Bearcat BC898T Tones Question? wm820 Uniden Scanners 2 10-10-2007 10:27 PM
Uniden BC898T Trunk Tracker Scanner tlittle Old Classifieds Archives 4 08-11-2007 01:22 AM
Official Uniden BC898T Scanner Thread blantonl Uniden Scanners 74 09-10-2005 11:03 PM
The Uniden 246T: The next paradigm shift in our hobby... br0adband Uniden Scanners 3 04-29-2005 09:03 PM
