Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
  #221 (permalink)
Old 08-01-2009, 12:48 PM
My ARC500 software wont connect to RadioReference for the lat two days
I think I have the latest build....1.12 build 6.
I think it must be related to turning off the old way of connecting and going to SOAP.
Anyone else having the problem....or can anyone help?
It wont connect for either trunked or conventional.
The messeage says.. "RadioRefDisconnected, wait retrieving HTTP data"
From there it does nothing....
  #222 (permalink)
Old 08-01-2009, 5:15 PM
mtitteri's Avatar
You are definitely not alone, my friend. My Arc500 gives exactly the same disconnect error, while Arc-XT connects fine.
At this point, I'm just amazed that more people haven't mentioned it.
Best Regards,
Mark - Winter Park
  #223 (permalink)
Old 08-01-2009, 6:08 PM
Unhappy mine too
I haven't tried yesterday but mine won't connect today either. Let me know if you find the fix.
Jason
jjh4gkk@yahoo.com
  #224 (permalink)
Old 08-01-2009, 6:22 PM
ac9f's Avatar
Default Upgrade problem
I tried to download the program from Butel but would not let me. When I opened my ARC 500 program and asked it to look for the latest software it told me I had the latest. So unable to upgrade program and cannot connect with the one I have.
Chuck
AC9F
  #225 (permalink)
Old 08-01-2009, 8:13 PM
Apparently Radioreference.com changed the web interface specs and all Butel software (probably others too) needs an upgrade. The problem is that Butel is closed for vacation until August 10. Bad timing, that. I suppose we'll just have to wait it out.
  #226 (permalink)
Old 08-01-2009, 10:49 PM
Location: Waldheim, LA USA (St. Tammany Parish, Louisiana USA)
Thught I was going hyper-nuts!. I thought it might be a conflict after I installed ARC-XT PRO on same machine. ARC-XT PRO connects to radioreference.com fine; however; ARC500 will not. Removed and re-installed ARC500 with same results. Even loading ARC500 on another computer proved fruitless. Hopefully the issue will be resolved soon.
Grecom PSR-500, PSR-600, PSR-800, ARC500PRO
Uniden 996XT, Uniden 396XT, BCH536HP w/ProVoice, ARCXTPRO, ARC536PRO
Byonics GPS2
  #227 (permalink)
Old 08-02-2009, 8:47 AM
DaveNF2G's Avatar
I'm amazed that people don't read what is on the Forums. There are several threads about this in multiple forum areas.
David T. Stark
NF2G WQMY980 KYR7128
  #228 (permalink)
Old 08-02-2009, 9:30 AM
fmon's Avatar
Silent Key Jan. 14, 2012
Gommert must have been "texting while driving" on this one.
Frank
RR Wiki Programming Shortcuts
  #229 (permalink)
Old 08-02-2009, 11:58 AM
Default RR's New "SOAP" Based Web Service
Butel's ARC500 ver 1.12 build 6 isn't connecting to the new RR "SOAP" based Web service. I am confident Butel and RR are aware of the bug and will resolve this issue shortly.
Richard
WB5CCO
Byonics GPS2
  #230 (permalink)
Old 08-02-2009, 12:32 PM
ScanWI's Avatar
MN & WI DB Admin
I'm having the same issue with the ARC-500. it will connect for 1-2 secs and then say it's dissconected and switch to saying "wait retrieving HTTP Data." and just sit there.
  #231 (permalink)
Old 08-09-2009, 1:28 PM
Default Arc500
Mine as well will not connect on ARC500. Also i see alot of posting about Butel coming back on the 10th and thats wrong. I dont know where that date came from but they dont come back from their great timing of a vacation till the 15th of august. It tells you that when you go to contact them and send them a message from there website.
  #232 (permalink)
Old 08-09-2009, 3:07 PM
Butelsoftware's Avatar
ARC500 V1.13 is now online and uses the new SOAP webservice.
Gommert
Butel Software
>>> Visit us at the 2018 Dayton Hamvention! SDS100 will be on demo! <<<
Dutch Design: best selling scanner software in the USA
US Sales: 1-800-SCANNER http://www.scannermaster.com/?Click=41054
  #233 (permalink)
Old 08-09-2009, 4:18 PM
fmon's Avatar
Gommert
Butel Software
Thanks, also corrects reband calculator.
Frank
  #234 (permalink)
Old 08-09-2009, 5:00 PM
Thank you, Gommert. I know how important vacations usually are, so I appreciate your coming back from vacation early.
Can you put looking at why ARC396 and ARC996 don't download from the Butel website on your to do list?
  #235 (permalink)
Old 08-09-2009, 6:19 PM
Technically I'm still on vacation but already back home. The 396 downloads should work again but it's very busy at the moment.
Gommert
Butel Software
  #236 (permalink)
Old 08-09-2009, 6:33 PM
Gommert
Butel Software
Wheres the Import button to actually download conventional or trunked systems? My screen gives me all options but cant find the button to actually download the data? Thanks.
Nevermind. I put my screen in high res mode and I'm getting the full menus now. sorry my mistake...
  #237 (permalink)
Old 08-10-2009, 2:04 AM
Gommert
Butel Software
I understand and appreciate you working on these issues while you're still on vacation. Or is it Holiday in The Netherlands?
  #238 (permalink)
Old 08-10-2009, 3:13 PM
The next build will have a sizeable window.
Gommert
Butel Software
  #239 (permalink)
Old 08-10-2009, 5:12 PM
Downloaded ARC500 Ver 1.13 Build 1 from server 2 today. Connects with RR.
All is well.
Thanks Gommert!
Richard
WB5CCO
Byonics GPS2
  #240 (permalink)
Old 08-11-2009, 5:55 PM
I just uploaded 1.13 build 3 that has a resizable import window.
Gommert
Butel Software
