Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
  #461 (permalink)
Old 08-24-2017, 11:14 PM
u2brent's Avatar
FWIW, mine has never had a tray icon, you can only see it in the Windows Device Manager window under Ports, unless the driver is wrong. Except while in USB mode to program. Did the cable go bad? Try a different USB Port? A different PC if available. Is the cable firmly seating in the radio jack?
  #462 (permalink)
Old 08-25-2017, 1:16 AM
TailGator911's Avatar
Anyone have any good ideas about how to get the virtual display working on this. ARC500 - WS-1065 - Win7,. No help from Butel. Any suggestions greatly appreciated - thanks
Scanners: BCD536HP, BC895XLT, PRO-2006, PRO-2051,WHISTLER TRX-1, WS-1065, Misc.
Shortwaves: ICOM R75, ICOM 746 PRO, SDR#
Amateur: ICOM 746 PRO (2m), YAESU 2800M, YAESU VX-7R, ICOM IC-T21A
  #463 (permalink)
Old 09-11-2017, 4:02 PM
I have windows 10 and ARC500Pro. Same symptoms. buttons work but no visual.
  #464 (permalink)
Old 09-17-2017, 4:36 AM
Butelsoftware's Avatar
Please try the new release ARC500 V1.30 (basic and pro).
I bought several '20-546' PC cables of ebay sellers and was able to find a workaround for the cables that showed this problem.
In the Download/Upload window make sure to select the 'cable type 2' option before running Virtual Control.
Gommert
Butel Software
>>> Visit us at the 2018 Dayton Hamvention! SDS100 will be on demo! <<<
Dutch Design: best selling scanner software in the USA
US Sales: 1-800-SCANNER http://www.scannermaster.com/?Click=41054
  #465 (permalink)
Old 11-13-2017, 7:38 PM
Freqed's Avatar
Anyone else experiencing Alpha tag issues when importing RR system info? All my AT's are coming up with the Description info in the AT box, not the actual AT as listed in the RR system info. I have loaded OKWIN system and the TGID's I want and have like 10 TGID's that all say Sheriff Dispatch instead of the actual Alpha Tag info. This is also happening in my ARC XT and 996 software as well.
Thanks,
Ray
TRX-2
BC780XLT-BC796D
BCD996T/BCD996XT(GPS ENABLED)/RH-96
PSR-600
  #466 (permalink)
Old 11-14-2017, 12:48 AM
kd7ckq's Avatar
Under ALPHA TAG OPTIONS.
I use the [Use short Alpha Tag (if available)] and that seems to import the correct Alpha Tag.
  #467 (permalink)
Old 11-14-2017, 7:49 AM
Freqed's Avatar
OK I will check that out, Thanks.
TRX-2
BC780XLT-BC796D
PSR-600
  #468 (permalink)
Old 11-14-2017, 8:47 AM
In ARC you can set you preference, either description of the short tag.
Gommert
Butel Software
  #469 (permalink)
Old 01-29-2018, 5:25 PM
zac's Avatar
zac zac is offline
I downloaded the software for demo mode. How can I tell if registration keys work
  #470 (permalink)
Old 01-29-2018, 5:32 PM
Default Keys
Open Arc 500, click on help and then click on Register. Enter the keys, click ok and you are done. Put keys in a safe place as Butel will charge you if you loose them and have to reinstall. You do not need them to download and install updates.
  #471 (permalink)
Old 01-31-2018, 8:20 AM
In the software select Help _ About. It will read Full version if the software is correctly registered.
Gommert
Butel Software
  #472 (permalink)
Old 01-31-2018, 10:20 AM
I have updated and reloaded drivers reinstalled software, tried everything I can and still no virtual control on my ARC500 + WS-1065....any ideas?
  #473 (permalink)
Old 01-31-2018, 10:39 AM
Default Reinstall
When you do a reinstall, you should do a shut down and clean reboot rather than a restart. I have yet to see a program that completely uninstalls without leaving useless files somewhere. A reboot will help to close those files. Then do your reinstall(s). There is only one driver that I had to install in earlier versions of Windows, and Win 10 found the proper driver when I plugged in the cable.
  #474 (permalink)
Old 01-31-2018, 12:10 PM
I will go back and do it all over again. I have a new machine now running Windows 10. Let me give that a try - thanks for the reply.
  #475 (permalink)
Old 01-31-2018, 11:26 PM
Well I did complete shut down, don't know why when I just did a clean install of this program (ARC500) from the CD on a new Dell fresh out of the box. Virtual box comes up, I can do minimal navigation on the keys, but no visual readout. Completely stumped.......
  #476 (permalink)
Old 02-01-2018, 4:00 AM
Use the latest release available at our website Butel Software
That version works will all different cables available.
Gommert
Butel Software
  #477 (permalink)
Old 02-01-2018, 8:54 AM
Downloaded latest release, imported config fine from scanner, clicked on virtual display - nothing. Buttons work, Scan Manual all of that, but no action from the scanner on the screen,,,,nothing changed. I have ProScan, Win500, the TRX-1 Scanner Control - they all work great. I cannot get the Virtual Control to work in ARC500. What to do.
  #478 (permalink)
Old 02-01-2018, 3:02 PM
What is the version number?
Gommert
Butel Software
  #479 (permalink)
Old 02-01-2018, 4:39 PM
1.30 build 2 - full version...from the 'About' tab
  #480 (permalink)
Old 02-02-2018, 9:12 AM
And which cable are you using? You may need to check option 'cable type 2' in the upload/download window.
Gommert
Butel Software
