  #41 (permalink)
Old 01-03-2008, 04:31 AM
Butelsoftware's Avatar
Send a message via Skype™ to Butelsoftware
Originally Posted by Mark01
Well I can answer my own question.the flexstep bug will be fixed in the next build of the
software .I did not get to check the Yahoo ARC500 group until today as my membership was pending,but sure enough it states this at the Yahoo group.
The latest release 0.95 now has Flexstep support,
Gommert
www.butelsoftware.com
http://www.butelsoftware.com
Visit us at the Dayton Hamvention booth 401!
US Sales: 1-800-SCANNER http://www.scannermaster.com/?Click=41054
  #42 (permalink)
Old 01-06-2008, 05:52 AM
Default virtual control question
I am in the learning curve right now with the ARC500 software and so far I like it. I already have ARC396PRO so I'm used to the way this software operates. I was wondering though, are there any plans to make the virtual control window viewable when minimized just like the ARC396PRO is? I like to minimize the window but still be able to see activity in the smaller window down near the task bar.
Thanks Gommert and keep up the good work.
powerhouse
  #43 (permalink)
Old 01-06-2008, 10:10 AM
Default Global Settings
Could someone, please, give an explanation of the Global Settings; particularly LCD Blinking and LED Blinking and what the sliders control.
Thank you.
  #44 (permalink)
Old 01-06-2008, 02:19 PM
Yes, I got more requests for a mini VC so will probably be in next release.
Gommert
  #45 (permalink)
Old 01-06-2008, 02:21 PM
The sliders set the LCD/LED blinking on/off time in mS. In the scanner these are set in the 'GLOB' menu.
Gommert
  #46 (permalink)
Old 01-15-2008, 06:41 PM
Default robcorden
The moving scanlists function in my ARC500 software does not work. Anyone have any suggestions on moving scanlists?
  #47 (permalink)
Old 01-16-2008, 06:35 AM
Can you post more details, we verified using the latest 0.95 and moving scanlists works in that version.
Gommert
  #48 (permalink)
Old 01-18-2008, 07:39 PM
Default robcorden
I have 0.95. I open the "Move Scan List" function and put in from and to perameters and click on apply and nothing happens! Am I missing something?
  #49 (permalink)
Old 01-19-2008, 08:31 AM
Did you select an option (move/copy/swap)?
Here is an example:
In the Object Browser click on 'conventional' and enter a frequency and set scanlist to for example 2.
Now open the Move Scanlist window and set
'From Scanlist: 2'
'To Scanlist: 1'
Select option 'Move' and click apply, in the grid you will see that -2 changed into -1.
Gommert
  #50 (permalink)
Old 01-19-2008, 05:26 PM
Default robcorden
Thanks! That helps. Guess I was going about it all wrong!
  #51 (permalink)
Old 01-22-2008, 09:49 PM
My scanner indicated to that there were no tsys (talk group system indicated for my talk groups) After reading a post in the ARC500 Yahoo group I looked at the Object Editor for talk groups within the ARC500. I was surprised to see that the whole column titled trunk system was blank. Since I never download from the radio and I absolutely know I did not edit the column I am wondering how did the information disappear. I frequently upload to the scanner and that probably occurred after trunk system info went blank which caused the scanner to indicate no TSYS indicated. It was an easy fix since there was only one system involved and I used the fill button.
I am wondering have you seen this before and what caused it.
Thanks,
William
  #52 (permalink)
Old 02-05-2008, 03:02 PM
Default Yahoo Group ARC500 - Problem saving SERVICE SEARCH
Wondering if anyone has the impression that the Yahoo ARC500 group are not posting messages. I tried to add two messages to a current post and nothing happened with respect to the following:
"In ARC500@yahoogroups.com, "swca1985" <wbern@...> wrote:
I am entering the service search mode. I enter the service type,
e.g. amateur, group frequency, alpha tag, assign it to a scan list,
designate search mode, put delay on, enter delay time. After
entering this information I click save. At that point all my information
disappears from the cells I just populated. I also tried
uploading the information to the radio without saving. The information in the
cells also disappear. Am I doing something wrong - if so what should I do? Or is it the
software?
Thanks -
William
I can duplicate this, the software ignores the 'amateur' setting in
service search mode. Will be fixed in the update coming end of this
week.
Gommert
www.butelsoftware.com"
This is what I tried to post twice but it never appeared. Maybe there is some technical issue with posting at the group.
I also wanted too add that if you program an amateur Service Search in the scanner and then download to the ARC software the software adds a phantom frequency group (#7) which does not exist. Thereafter the problem of not being able to save the ACR information or re-upload is the same - it disappears.
GRE PSR-600
IC-746 PRO
  #53 (permalink)
Old 02-05-2008, 04:50 PM
mikebennett's Avatar
I had the same thing happen.
  #54 (permalink)
Old 02-05-2008, 05:29 PM
Gommert -
Wondering why the messages are not being posted to the Yahoo Group ARC500?
GRE PSR-600
IC-746 PRO
  #55 (permalink)
Old 02-05-2008, 05:50 PM
DaveNF2G's Avatar
Did the message never appear, or just not appear when you returned to the group after posting?
New messages posted to Yahoogroups won't be visible until the next time you log on. Messages posted to moderated groups will be visible after they are approved.
David T. Stark
Educator - Criminal Justice, Sociology
NF2G WQMY980 KYR7128
"I'm everywhere, Focker!"
  #56 (permalink)
Old 02-05-2008, 06:10 PM
fmon's Avatar
Silent Key Jan. 14, 2012
Originally Posted by Williamb
Gommert -
William, that message has been listed on the Yahoo PSR500 Butel group since yesterday morning. In fact this part of your above (his response) is copied from the Yahoo group.
Code:
week.
Gommert
Frank
RR Wiki Programming Shortcuts
  #57 (permalink)
Old 02-05-2008, 06:17 PM
Yes I agree. I tried to post additional information after that. On that group the initial post needs approval but after that posts seem to be posted immediately.
In the instance I am referring too additional posts made to that thread never were posted. I tried twice to add comments. The reason I asked was I was wondering if this was a problem other people have noticed.
GRE PSR-600
IC-746 PRO
  #58 (permalink)
Old 02-08-2008, 05:21 AM
I was out of the country with limited internet access, I just approved the messages.
Gommert
  #59 (permalink)
Old 02-12-2008, 06:13 PM
Wondering if anyone else is experiancing this in ARC500 V1 build 1 I'm getting very slow sluggish performance when using the virtual control window, the window basically freezes at times and pressing the keys deliver no feedback to the scanner at times because of the freezing up issue.I'm running a fairly fast computer (2.8ghz/1 gb ram),I also use ARC 396 and that virtual window works great compared to this.
  #60 (permalink)
Old 02-12-2008, 08:02 PM
fmon's Avatar
Mark,
Mine is working fine.
Frank
