Old 11-13-2007, 02:27 PM
Default ScanControl 6.1
I need help figuring out why I can not get my local trunked system to work using the ScanContol 6.1. This is the first time I have used a program to program my BC796D.
I had every thing working fine before I dragged every thing from RR into the program and reprogrammed the radio. I keep getting a message that it cannot find the control channel.
My local system is Roseville, Ca, a Motorola Type II. I have tried to use all Plans(1-4) and have had no luck. Everything worked fine before I reprogrammed it. I use Firefox as my browser and every thing programmed into my radio, channels and talk groups.
I have also posted on a Yahoo discussion group for the BC895XLT.
Old 11-13-2007, 02:43 PM
Wiki Admin
Data Grabber does not work well with Firefox - Ken is working on a fix, as detailed on the Scan Control yahoo group. Likely this is part of your issue, though it may not be the only thing.
By the way, Netscape doesn't work well either. That too is being worked on as I write this.
73s Mike
Old 11-13-2007, 02:50 PM
Send a message via Yahoo to mule1075
check and make sure the control channel did not get locked out.i know it sounds crazy but that is what happened to me.actually the whole bank was locked out after i loaded it into the radio.might not be the problem though. thats just what happened to me.
Adam Donahue
Uniden
BCD996T BC796D BC780XLT BC8500XLT BC250D
Feeding The Pittsburgh Area From Time To Time On Proscan
Old 11-13-2007, 10:49 PM
fmon's Avatar
Adam is correct, my 785D trunking freqs all paste locked out. Using IE7
Frank
RR Wiki Programming Shortcuts
Similar Threads
ScanControl 6.1.0 Upgrade Problem compubandit Scanner Programming Software 4 11-16-2007 12:18 AM
ScanControl, Multi Sessions GreatLakes Scanner Programming Software 0 01-22-2007 07:15 PM
ScanControl, Multi-Sessions Possible? GreatLakes Scanner Programming Software 1 01-03-2007 08:26 PM
ScanControl Version 5.2.x Now Available kdragos Scanner Programming Software 5 09-12-2006 10:53 AM
ScanControl update adds new Uniden models! MacombMonitor Scanner Programming Software 5 02-25-2006 08:21 PM
