Old 11-15-2007, 10:18 AM
mlconnell's Avatar
Default Help with BCD996T and AGC Tweak APCO P25
When I peform the below instructions everything happens except I get this message at the bottom of the display:
ERR:--- 8 AUTO
T 1. 43 1. 65 1. 87
Can anyone give me a hand please?
Here is the procedure for tweaking AGC for P25 Reference
Gain and P25 Res Time for the BCD996T.
1. Power on the 996T while pressing the HOLD/RESUME button. The display will rapidly flash between red and green. The display will then appear as normal.
2. Press in the function knob. WHILE THE F IS FLASHING IN THE UPPER LEFT OF THE DISPLAY, press the volume knob ONCE.
3. The text "P25 RES TIME" appears in the bottom line of the display, with +0 next to it.
4. Rotate the scroll knob to adjust the setting. -7 was the recommended setting for the 396T.
5. Once set to the desired level, press the scroll knob.
6. Press the scroll knob again, and while the F is flashing, rotate the knob. P25 REF GAIN now appears, also with a +0 to the right of it.
7. Rotate the scroll knob to adjust the setting. +3 was the recommended setting for the 396T.
8. Once set to the desired level, press the scroll knob.
Michael C.
BCT-15
YAESU FT-2800M
Old 11-15-2007, 10:32 AM
mlconnell's Avatar
sorry guys but this happens after I hit the F knob and press the vol knob.
Michael C.
BCT-15
YAESU FT-2800M
Old 11-15-2007, 11:01 AM
mlconnell's Avatar
Sorry wrong forum. My apologies.
Michael C.
BCT-15
YAESU FT-2800M
Similar Threads
BCD996T Firmware Update 1.03.11 Available UPMan Uniden Scanners 200 02-12-2010 02:24 AM
Uniden Agc Tweak Question ? charles400 Uniden Scanners 1 09-21-2007 04:50 PM
Noob Question - Digital/Analog AGC Tweak? Hypervista Uniden Scanners 3 04-26-2007 09:51 PM
BCD996T Mini-Review Part 1 of 2 scancapecod Uniden Scanners 25 08-11-2006 02:48 PM
