Old 11-18-2007, 10:10 AM
Default Cable ?
What cable do I need for the PRO 96 ?
PRO-97
PRO-2039
PRO-2045
PRO-2096
PRO-96
PRO-2006
Old 11-18-2007, 10:59 AM
Several different cables should work:
  • GRE's USB Scanner Data Cable. This is also the cable that is shipped with the PSR-500.
  • RadioShack's 20-047 USB Scanner Programming Cable (identical to the above GRE cable except for color)
  • RadioShack's 20-289 serial cable. Requires a serial port. Also, some users have had trouble with this cable (it's somewhat sensitive to differences between radios and serial port hardware). This cable seems to work "best" with a USB-Serial adapter - perhaps because such an adapter is able to "drive" the cable harder than the serial port on a PC motherboard.
Additionally, some people are able to get cables from other scanners to work with the GRE-made PRO-9x radios (like the PRO-96). Some that I've heard of are the cables for the Yaesu VR-500 and the Icom IC-2800.
EDIT: whatever you do, don't buy RadioShack's 20-049 cable. It does NOT work with the PRO-96 (or the 92, 93, 95, 97).
Old 11-18-2007, 11:13 AM
hoser147's Avatar
Check out this thread: http://www.radioreference.com/forums...ad.php?t=72957
Hoser
Good Scanning Hser
http://www.radioreference.com/apps/audio/?feedId=165
Similar Threads
Serial -vs- USB cable (GRE) aaronp Radio Shack Scanners 3 03-10-2009 11:34 AM
Serial Cable vs. USB Cable emslt245 Scanner Programming Software 9 06-17-2007 07:49 PM
A definitive cable answer please Lexxx Uniden Scanners 8 02-03-2007 12:26 PM
GRE USB Cable n4voxgill Radio Shack Scanners 6 06-15-2006 03:45 PM
Pro 93 Computer cable namrats Radio Shack Scanners 9 03-08-2006 02:03 PM
