Old 12-12-2007, 02:25 AM
Question ARC996 Pro Recording Problem
I have the ARC996 Pro software with Windows XP operating system. I am able to briefly record from the scanner but either the software or the scanner is rebooting my computer ( after about 5-10 min). It may be "something" running in the background of my computer and just takes a while for it to load up.
Anyone have this problem before or maybe know how to cure the chaos?
As a side note, to load the ARC996 software where it recognizes the scanner, I must quickly load the program and click the RS232 setup button or the COM 1 port will not be available...
Thanks for any guidance that can enlighten me!
Old 12-12-2007, 06:42 AM
mike_s104's Avatar
As much as I would like to say it's the Butel software, I can't. Sounds like something else on the PC.
Not trying to bombard you with questions, but just some basic troubleshooting...
Have you tried the scanner with the same cable with a different PC? Are you using a serial to USB adapter? What OS is installed on the PC? Have you tried uninstalling any new software or hardware? Have you checked the memory on the PC with something like Memtest (http://www.memtest.org/)? Have you tried installing new drivers for the motherboard (if using a real serial port, which you probably are if its COM1) or new drivers for the USB to serial adapter (if using a device like this)? Have you tried a new cable? Have you tried the USB cable using the front port on the scanner? How old is the PC? Have you tried uninstalling any unused application? Have you tried just a good 'ol clean up with Windows Disk Cleanup and a defrag? Do you have adaquite hard drive space for recording? Have you tried a fresh install of the OS? Have you tried opening the Task Manager (Ctrl + Shift + Esc) to see what else is running? (see screen shot attached).
Old 12-12-2007, 09:51 AM
lemish's Avatar
Mike, speaking of recording issue... can you look at this post?
http://www.radioreference.com/forums...ad.php?t=89166
BCD996T - BCD396T - BCT7 - VX170 - VX1R - DJ580 - DR600
Similar Threads
ARC15 PRO and Vista (Graphic Problem) jobes Scanner Programming Software 16 09-28-2007 02:47 PM
Arc250 pro beta version Problem timjude Scanner Programming Software 1 12-27-2006 07:33 AM
Pro 95 Problem amonte28 Radio Shack Scanners 13 12-04-2006 12:06 AM
Easier to Read Manual for the Pro 97/2055 trunker Radio Shack Scanners 7 07-17-2006 10:32 PM
Weird EDACS scanning problem c0wb0yup Alabama Radio Discussion Forum 1 02-20-2006 09:57 AM
