| Scanner Programming Software This is the place to discuss scanner programming and control software. |
01-05-2008, 04:18 PM
PSR Edit Import from Radio Reference database
I can't get the import feature on PSR Edit to work. I have version 1.38.
I am trying to import conventional frequencies under Florida, Areawide Florida Frequencies, Federal, U.S. Customs & Border Protection (CBP). The Import dialog box asks for the state and County, even though they aren't listed under a particular county, they're considered to be wide area, or statewide. Anyway, I can get as far as the last dropdown list, ("Sub Catagory") but it won't go any further. The "Import Frequencies" button is grayed out, and stays that way. What am I doing wrong?
Ken
01-05-2008, 04:38 PM
I am able to do it from 1.39, using the first county in the list: Florida/Alachua/Federal/Federal/US Customs Boarder Protection CBP
Try a county.
Also, make sure you have a frequency selected in order to import.
01-05-2008, 06:56 PM
As mentioned, make sure you check at least 1 frequency in the list to enable the import button.
01-05-2008, 07:33 PM
No frequencies appeared in the list.
Ken
01-05-2008, 07:58 PM
Did you try what I mentioned about using a county?
01-05-2008, 08:35 PM
Yes; no matter what combination of selections I make in the Agencies/Category/Sub Category drop down lists, no frequencies ever appear in the list. The "Import Frequencies" button remains grayed out.
If I try this with trunked systems (which I don't want), I can't get past the point where you select the trunked system; there's nothing in the drop down list to select, it just says, "Select trunked System".
Ken
01-05-2008, 08:58 PM
Your RR subscription hasn't expired has it? I had a similar report before, and that was the cause of it.
01-05-2008, 09:09 PM
Wiki Admin
There's no 'premium subscriber' for W4KRR in the message window....
73s Mike
01-05-2008, 09:18 PM
Yes it had. I just never noticed it.
....I just renewed; I'll try the import function now.
EDIT: That was the problem; it works now!
Ken
01-05-2008, 09:44 PM
I need to see what the error response is when that happens. PSREdit should tell you that's the issue. I need to look for the error message on those screens.
01-05-2008, 10:05 PM
Mike, there was no indication that anything was wrong, it simply wouldn't display any frequencies when you finished selecting the last drop down list; the "Import" button remained grayed out.
Ken
01-05-2008, 10:51 PM
Yeah, that's the issue. There's no code in PSREdit to detect that. I need to get that in there, but I'm not sure at this point where that error message appears, so I need to add it in a few areas.
