Old 01-06-2008, 10:11 PM
captaincraig44's Avatar
Send a message via AIM to captaincraig44 Send a message via Yahoo to captaincraig44
Default Object ID numbering Win500
Is there an upper limit to the id number than an object can be assigned in Win500 or in the radio itself? I have some object that I have arbitrarily assigned ID's of 2500+ and the software reassigns them when I send the file to the radio.
Craig Mills
Denver, CO
MNN //113//
Old 01-06-2008, 10:43 PM
TES's Avatar
TES TES is offline
If I try to enter an integer equal to or greater than 100000 in my copy of Win500 I get a message telling me to enter an integer BETWEEN 0 and 99999. I believe that the software will actually allow any integer FROM 0 TO 99999 in keeping with Win500's ability to create P500 files with 100,000 objects.
Old 01-07-2008, 07:46 AM
mikey60's Avatar
The radio itself is capable of 1852 objects, numbered 0-1851. TSYS, SRCH, and SWPR objects take up multiple IDs depending on the system type.
http://www.psredit.com
Old 01-07-2008, 10:01 AM
So the radio itself will not allow an object to hold an ID of over 1851 then, correct? That's kind of a bummer. I only say this because I'm setting up my objects with some logic given to the ID numbers I assign them (ex Denver PD District 1 Dispatch is object 0410, with all the sub channels 411-419, DPD Dist 2 is 0420, etc.). Doing this can leave some object ID's unused and as such I either have to eat the unused object IDs, or assign non-logical numbers to some objects. Not a big deal for seldom used objects, but kind of a disappointment.
Craig Mills
Denver, CO
MNN //113//
Old 01-07-2008, 10:11 AM
TES's Avatar
TES TES is offline
So the radio itself will not allow an object to hold an ID of over 1851 then, correct? . . .
I suspect the 0-1851 limit has something to do with the following from the PSR-500 Owner's Manual: The Object ID is the “address” where the object is stored in memory.
Old 01-07-2008, 10:59 AM
Thanks for that catch TES, that makes sense.
Craig Mills
Denver, CO
MNN //113//
Similar Threads
PSR-500 Object numbering n4jri GRE Scanners 1 12-03-2007 09:45 AM
County Fire EMS Station Numbering colliers_628 Virginia Radio Discussion Forum 21 11-22-2007 11:16 PM
Win500 Data Corruption - could kill trunking DonS GRE Scanners 11 11-15-2007 10:09 PM
Do LTR systems ever have repeaters numbering higher than 20 newsalan LTR Trunking 3 11-29-2006 09:44 AM
Fire Dept. Station numbering for counties colliers_628 Ohio Radio Discussion Forum 5 08-01-2006 01:03 AM
