Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
Old 01-18-2008, 9:31 PM
Smile help with win96
Do you have to have the exel software on your computer to download frequencys from RR to win96? Thanks for any help.....KYBILL
AOR2002
AOR8000
AOR 8200MK III
PRO96
SONY 2010
Old 01-18-2008, 9:35 PM
Wiki Admin Emeritus
Not at all - win96 can connect natively. I see you already have the premium subscription - I'm sure Don or someone can point you to the correct menus, as I don't have Win96....73s Mike
[edit] This should be in the software forum - moderators, please move. Thanx
Old 01-18-2008, 9:54 PM
N2MWE's Avatar
Go to File, Web Import, then RadioReference. It will then give you a choice of trunking or conventional. Choose your poison, then when the box open, sign in and start downloading!
Welcome aboard!
I've done my bid for king and country
Old 01-18-2008, 10:07 PM
Thank you so much,sorry I posted on the wrong forum, I'm a newbie in the forum. 73"s Billy N4DIF
Old 01-19-2008, 12:12 PM
loumaag's Avatar
Silent Key - Aug 2014
Originally Posted by kybill
...sorry I posted on the wrong forum, I'm a newbie in the forum. 73"s Billy N4DIF
Not a problem, moved to the appropriate forum.
Old 01-24-2008, 12:19 PM
Default programming from 96
how do i set up the import from RR for trunking to the scanner...
thanks much
conventional importing works great...
Old 01-24-2008, 4:12 PM
loumaag's Avatar
thanks much
Assuming you mean with Win96, it works the same way, just choose Trunked instead of Conventional.
Old 01-24-2008, 7:29 PM
Default trunked is selected
but when it asks to be imported it does nothing... does not interface with win96 so that i can upload to the scanner... now the 'conventional' window has the proper buttons and will upload just fine....
thanks much for responding..
Scott
Old 01-24-2008, 7:41 PM
TES's Avatar
TES TES is offline
Are you 'clicking' the Import This System button?
Old 01-25-2008, 8:53 AM
loumaag's Avatar
To add:
After selecting the sites/TG's you want.
