Scanner Programming Software This is the place to discuss third party scanner programming and control software.
  #501 (permalink)
Old 11-14-2012, 11:17 AM
Ronaldski's Avatar
Mid-MI DB Admin
Question, why cant you just put in the frequencies, but 15 MHz lower?
  #502 (permalink)
Old 11-14-2012, 11:22 AM
Wiki Admin Emeritus
If you were doing it manually, Ron, you're absolutely right - but that's only 1 step. There are a couple more - namely resetting the site type and putting in the custom table (and I'll add the additional wrinkle that the table is only needed for analog and mixed mode Motorola type systems). I'm pretty sure the Easier to Read manual covers this - along with the required table values.
EDACS systems only require that you drop the frequencies (as you suggest) and maintain the correct LCN order.
  #503 (permalink)
gonzalu's Avatar
Ah ok, thanks... I think I get it now...
Manny, N2MAV - Amateur Extra
BCD536HP, BCD996XT, HomePatrol, BC125AT, PCR1000, PRO-2042, OS-535
First Scanner: Realistic PRO-24
  #504 (permalink)
Old 11-14-2012, 3:32 PM
cpuerror's Avatar
I believe Jan is talking about the rebanding tables for the custom search feature. Not that many people know of it or use it and until now the settings haven't been retained for it. However, I added this to my todo list so I won't forget for the next version.
FreeSCAN for Uniden DMA scanners, IRLP*Me for iOS devices
Twitter - @FreeSCAN
  #505 (permalink)
Old 11-21-2012, 12:28 PM
May I just say here that FreeScan is the only reason I havent thrown away my old Windows laptop. I cant get over the fact that we get all this functionality in a scanner programming software package and yet its free. Kind of makes me feel guilty. Thanks cpuerror and Sixspot.
  #506 (permalink)
Old 11-22-2012, 9:56 PM
cpuerror's Avatar
Great to hear that you like it, awattam.
Twitter - @FreeSCAN
  #507 (permalink)
Old 02-21-2013, 8:24 AM
Originally Posted by ATLiens View Post
I have had fun learning to program my 996T. I have created my own files and they needed some fine tuning. So I installed one of Marshal's starter .996 files in my scanner. It was just to get an idea on how a good file should work. Now that I am trying to re-install new files, it has been a nightmare.
I have searched and cannot find the solution. I am getting these error messages:
"Insufficient scanner resources to Continue"
or
"FreeScan could not communicate with the scanner, or the scanner is not recognized as being compatible. Response received: MDL
I have rebooted, did a reset on the scanner, deleted and re-installed FreeScan with still no luck.
Suggestions?
Has this question been awnsered? I have searched the thread and the internet and must have missed it. I'm having the same issue and could use help - please PM me if you have the answer thanks! dieing to get this 396xt programmed and I only have WIn8
__________________________________________________ _____
Follow my blog: http://nicktoday.com
de N1IC - Longwood, FL
  #508 (permalink)
Old 02-21-2013, 12:17 PM
I got it fixed
  #509 (permalink)
Old 09-26-2013, 12:17 PM
ad5kl's Avatar
It seems like the option to change the backlight color per channel is now missing. I go into Edit Conventional Group and the option is not there anymore. I usually assign a color to service (blue for police, red for fire, etc.)
I also noticed the volume increase/decrease setting by channel is no longer available on that same screen. Have those options been eliminated?
Other than those minor things, I really like the software & it is very helpful. I'm running latest version 2.15 for Windows 7 with 396XT and 996XT scanners.
  #510 (permalink)
Old 09-26-2013, 2:58 PM
cpuerror's Avatar
Turn off simple view
Twitter - @FreeSCAN
  #511 (permalink)
Old 10-22-2013, 3:27 PM
Default Trunking Sites and Groups
I have just started using Freescan on my 396T after being afraid to try it for three years. Three years of fun wasted. I love it. Question. Downloading Washington State-Snohomish County-Emergency Services Trunk, there are eight sites. I did not deselect any of them and gave them all one site number. I selected only the fire TGID's and gave them group numbers. When it downloaded into the 396, it put each group with each site there by creating the same groups under each site. What I wanted was one site with the groups under it like the old days. Make sense yet? I took the Boeing trunk and manually inputed their control channels (like the old days) then manually put in the groups. It showed up like I wanted it to. How do I get all the sites in without putting groups under each one. Manually put the control channels in and then download groups? (haven't tried that yet) Only question so far but I'm going to try loading up a friends 396XT this week. We'll see how that goes. Thanks Lynnn
  #512 (permalink)
Old 10-22-2013, 4:32 PM
cpuerror's Avatar
The 396T only supports one site per system, so to get all 8 sites in there, 8 systems have to be created with the same set of groups.
You can combine the control channels together in one site, but if you do you might miss some traffic because the scanner will only listen to one control channel at a time and ignore the others.
Twitter - @FreeSCAN
  #513 (permalink)
Old 10-22-2013, 4:41 PM
Talking
OK, that makes sense. Thanks for the input.
Lynn
  #514 (permalink)
Old 10-23-2013, 10:18 AM
DDan's Avatar
Thanks for an awesome tool Assaf. My netbook has a 1024x600 display. In some cases the information in the windows extends below the bottom of the screen and there are no scroll bars to access the information that is off-screen. Is there a possibility of getting some scroll bars?
73 de W6KRU - Dan
BCD396XT BCD396T PSR-500 FRG-100 PRO-43 PRO-90 PRO-2050 FT-857 FT-90 VX-170 VX-3
RS 20-176 | Maxrad MFB8133 MYA8256 MUF8043 MLB3400
  #515 (permalink)
Old 10-23-2013, 1:52 PM
I can not find this software anymore. Anyone have a link for it?
Jacob
Equipment-MT 2000, BCD996T, BCD536HP
  #516 (permalink)
Old 10-23-2013, 2:00 PM
Wiki Admin Emeritus
Geez, can't use Google? Anyway, here's the site
http://www.sixspotsoftware.com/products/freescan
  #517 (permalink)
Old 11-12-2013, 1:37 PM
rhaasjr's Avatar
Default 346XTC support
Is there any time frame for adding support for the 346XTC to FreeScan?
Thanks.
  #518 (permalink)
Old 12-03-2013, 12:10 PM
c5corvette's Avatar
scannow.org website not working?
FREE Interop:
1. Pre-program agency radios with all national interoperability channels and frequencies.
2. Share radio frequencies / talkgroups with neighboring agencies on compatible radio systems.
  #519 (permalink)
Old 12-03-2013, 12:25 PM
KE4ZNR's Avatar
KE4ZNR@radioreference.com
Because the author moved his domain awhile back...
Current URL:
FreeSCAN - Sixspot Software
Marshall KE4ZNR
NC/SC Forum Moderator/Database Administrator
Frequently Asked Questions
Forum Rules & Guidelines
@KE4ZNR on Twitter
http://instagram.com/KE4ZNR
  #520 (permalink)
Old 12-03-2013, 12:41 PM
KE4ZNR's Avatar
I also went ahead and updated the URL link
in the Freescan user guide in the RR Wiki.
It still showed the no longer valid URL.
Marshall KE4ZNR
@KE4ZNR on Twitter
Tags
freescan
