  #721 (permalink)
Old 12-23-2011, 4:07 AM
N2ICV's Avatar
Question
Originally Posted by ProScan View Post
Sorting the system-group-channel column will show in alphabetical order. Click on the column header to sort.
I know I can do it that way ! Thats why I asked ...
"show the hits by alpha tags (system-group-channel) in alphabetical order """automatically"""" !
So I DONT have to "Click on the column header to sort".
Mike- N2ICV, WQOG646
When my ship comes in, I will be watching trains!
My Toys
  #722 (permalink)
Old 12-23-2011, 4:21 AM
ProScan's Avatar
It sounds like you are asking a suggestion. http://proscan.org/bug_reports_suggestions.html
ProScan - Taking Computer Aided Scanning To The Next Level!
http://www.proscan.org
bob@proscan.org
  #723 (permalink)
Old 12-23-2011, 7:21 AM
N2ICV's Avatar
Talking
It sounds like you are asking a suggestion. Bug Reports & Suggestions
Ok Done...Thanks. (-:
My Toys
  #724 (permalink)
Old 12-24-2011, 2:13 AM
i think proscan version 4.9 has a timer bug. timer being the trial timer. i downloaded the trial of this software about four days ago and it always pops up to let me know that it is a trial but the remaining time on the trial remains 30 days. thought you should know! ill be honest about it though and quit using or buy the software after my thirty days has passed because i respect your work and im thankful for your time and dedication to make this software! Thanks!
  #725 (permalink)
Old 12-24-2011, 3:56 AM
eaf1956's Avatar
Smile hmmm
I just installed that version. :-) Never would have seen that bug though cause mine is registered. Did find a small bug in another APP which I reported to the aurhor. This helps them to make the software better in my opinion.
Evansville In Feed provider
BCD 996XT Evansville, IN (EDACS and SAFE-T) Vanderburgh Co.
  #726 (permalink)
Old 12-29-2011, 8:35 PM
Default Stream Re-naming in source client
Howdy been streaming on one stream with ProScan source client noticed in version 4.9 the stream rename for RR streams.
What field renames the stream?
stream discription?
stream name?
Is there a delay?
Thanks Cheers Sly
  #727 (permalink)
Old 12-30-2011, 5:10 PM
ProScan's Avatar
stream discription?
stream name?
Is there a delay?
Thanks Cheers Sly
It shouldn't be renamed. Where do you see it and what is it renamed to?
No audio delay at the source. The IceCast server and the media player produces a small amount of delay intentional.
bob@proscan.org
  #728 (permalink)
Old 12-30-2011, 8:30 PM
MM I'm just a bit confused as what you mean by
Changed - Source Client - Stream to Radio Reference now can change the stream name.
Does this rename the RR stream at RR or just in ProScan?
Also ProScans been locking up on my XP system Unhandled Exception Report attached FYI
Thanks Cheers
  #729 (permalink)
Old 01-02-2012, 8:14 AM
ProScan's Avatar
Thanks Cheers
The stream name was hard coded "PS". Now with 4.9, it can be changed. Depending on the media player, it may show. WinAmp will show the stream name in parentheses along in the metadata area along with the metadata. Nothing is changed on RR.
bob@proscan.org
  #730 (permalink)
Old 01-02-2012, 8:17 AM
ProScan's Avatar
Thanks Cheers
The stream name was hard coded "PS". Now with 4.9, it can be changed. Depending on the media player, it may show. WinAmp will show the stream name in parentheses in the metadata area along with the metadata and the File --> View file info menu. Nothing is renamed on RR and it's not possible anyways..
bob@proscan.org
  #731 (permalink)
Old 01-03-2012, 7:29 AM
Thanks for that, I have just started broadcasting meta data and have rearranged my databases.
Outstanding program have just started to stream both streams with ProScan in the past the RR dropouts leadme to believe that scanner cast was preferd.
In the end RR kick you once a day that's great in my opp you get a much more stable stream.
Long time ProScan user.
Cheers Sly
  #732 (permalink)
Old 01-06-2012, 11:38 PM
Just a word of thanks for the recent upgrades to Proscan. I had been running v4.7 until I recently downloaded v4.9. The new features are great; love the big scope too!
Shawn WB6JWB
Paso Robles, California
www.TheRadioRoom.org
  #733 (permalink)
Old 01-07-2012, 9:02 PM
ProScan's Avatar
Appreciate the comments, thanks.
Next version will be out in a week or so.
bob@proscan.org
  #734 (permalink)
Old 01-10-2012, 10:06 PM
zzdiesel's Avatar
Bob, how long is a license good for? I just bought a new motherboard & CPU, and my times to install has been exceeded again.I install the Windows betas & etc. I hate to keep asking.
GRE PSR-600, BCD996XT - Mobile
Win500, Freescan, ID Tracker III
  #735 (permalink)
Old 01-10-2012, 10:27 PM
You have to unregister the software on your current hardware, install the new hardware and re-register and it will work. I ran into the same issues before.
  #736 (permalink)
Old 01-10-2012, 10:28 PM
zzdiesel's Avatar
Thanks. I'll start doing that after I get a new login.
  #737 (permalink)
Old 01-11-2012, 4:07 AM
ProScan's Avatar
Licenses are good indefinite. If just changing hardware, ProScan will work in the activation mode afterwards. If reformatting the HD, then the the activation has to be removed first and re-activated afterwards.
Email me on any license problems.
bob@proscan.org
  #738 (permalink)
Old 01-11-2012, 5:19 AM
ProScan's Avatar
Default ProScan Version 5.0
ProScan Version 5.0
  • Added - Recording Options - Recording prepend buffer from .5 to 5 seconds insures won't miss the beginning of audio.
  • Added - Logging Options - "New Entries Auto Sort".
  • Added - Recording Options - "New Entries Auto Sort".
  • Added - Startup Options - "Remember Last Sort Order Logging & Recording Grids".
  • Changed - Options - Rearranged options in tabs accordingly to catagory.
  • Fixed - Recorder - When using a date specifier for the folder, a new recording wasn't created for a new date.
  • Fixed - Recorder - When playback a recording and recorder attemps to record to that recording, the recorder would turn off.
  • Many more small improvements.
At this time, there are no known bugs or issues.
ProScan supports the BCD996XT, BCD396XT, BCT15X, BC346XT, BCD996T, BCD396T, BCT15, BR330T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D scanners.
ProScan is the most powerful and feature rich scanning software in this world.
bob@proscan.org
  #739 (permalink)
Old 01-11-2012, 11:04 AM
N2ICV's Avatar
Works GREAT!
My Toys
  #740 (permalink)
Old 01-11-2012, 12:55 PM
ProScan Version 5.0
Thanks!
But what does they do?
