| Scanner Programming Software This is the place to discuss scanner programming and control software. |
02-01-2008, 07:44 PM
Official ProScan Software Thread
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
02-01-2008, 09:52 PM
Wiki Admin Emeritus
Congrats Bob and good luck on the new release.
One suggestion for your web page; be sure to mention that a premium subscription to RR is required for the imports to work. The information can be pulled from our wiki, and the article can be linked to just like any other web page;
http://wiki.radioreference.com/index.php/Subscription
73s Mike
02-03-2008, 10:15 AM
73s Mike
Ok. Oversight on my part as there was many things to do at release time.
Next version will include an UASD import/export feature for DMA and non DMA scanners that ProScan supports.
Bob
ProScan
02-03-2008, 10:30 AM
Why not include the BCD396T as well since it's the same as the BCD996T?
Owner: Ohio_MARCS Yahoo Group
Equipment: PRO-96, BCD396T, BC246T, PRO-92, BC235XLT, BC245XLT, PRO-2016.
02-03-2008, 10:33 AM
I will be adding the BC15 after the next release(in a month) then the BC996 after that.
02-03-2008, 10:37 AM
Ok, I'll research the differences in the scanners and see what I can do.
02-03-2008, 11:18 AM
Wiki Admin Emeritus
No not quite. The 396 doesn't support multi site trunking, nor does it do any of the GPS based scanning features. However, I would bet that the 396 (and perhaps the BCT15) have several common functions in the firmware, and that should make it easier for Bob, to be sure.
The BCT15 doesn't do digital at all, and has less channel capacity. Interesting how the 3 are similar in some ways, not in others.
73s Mike
03-01-2008, 10:29 PM
I'm waiting on Build 3 to see how the naming of the recordings are. I think it's what's I'm looking for. :-)
03-02-2008, 09:50 AM
I'm waiting for someone to direct encode to mp3 or wma... Wow can't wait till build 3!!! I might take the plunge..
Just because I can, doesn't mean I will. (But I might)
03-02-2008, 01:02 PM
Hey Bob
How about adding the bc898t . Pro scan looks great might have to switch from trunk star pro.
Rick
03-02-2008, 02:32 PM
It should be what you're looking for. If not then let me know.
03-02-2008, 07:15 PM
Originally Posted by splash1
Hey Bob
Rick
I'm going to be doing just DMA type scanners from now on.
03-02-2008, 07:18 PM
03-02-2008, 08:07 PM
Hey Bob
Rick
Sorry for the double post. i don't know how to delete this.
03-06-2008, 10:06 AM
FYI - I'm in the process of changing my site to a new host and you may see it down until DNS servers get updated with the new host info.
03-06-2008, 12:35 PM
Your site is working for me @ 1330hrs. Looks like a neat pgm.
I don't know if the newer GRE digital scanners are "DMA" or not so excuse this if they are not. If so do you plan to add support for them ?
Rob
03-06-2008, 03:53 PM
Rob
No, I’m focusing exclusively on the Uniden products and will be adding the 15, 396, 246, and the 230 this year.
03-06-2008, 05:12 PM
Thanks for the info.
Rob
03-08-2008, 12:43 AM
ProScan Version 1.7 Build 3 Is Out!
I've added several items, many are user requested.
Import UASD files (all types) to ProScan (DMA and non-DMA scanner types)
Multiple sound cards support (capture)
Recorder user selectable filenames format
Recorder option lookup record flag from database
Recorder no loss
Quick Key assignment shows quick keys in use (DMA scanners)
Caption ICON user selectable
ProScan Sessions Manager
ProScan supports the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D Scanners. ProScan is feature rich with the friendliest user interface.
www.proscan.org
Bob
03-09-2008, 04:40 PM
Recorder use
Recorder no loss
www.proscan.org
Bob
Thanks Bob...
Build 3 names the files like I was looking for. (folders per each day would help organize, but I'm not complaining.) works beautifully!!
