Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
  #2841 (permalink)
Old 05-09-2017, 10:30 AM
nyair1's Avatar
Originally Posted by medic29 View Post
Just the one jack used for everything
Sent from my SAMSUNG-SM-G930A using Tapatalk
Ok what model is your computer? I just picked up this hp last week. Was doing some reading on hp forums about using that jack. Said you needed a 4 pin style jack in order to get the computer to see whats plugged in. Cable has 2 jacks off it. One is for mic input and one for headphone input. Ive been playing around with it last nite and cant always get that mic jack to see whats plugged in it. Im not sure if the jack is possibly bad??
Sent from my SM-G920V using Tapatalk
Chris
Western NY
Uniden 996XT(2), 15X(2), 396XT, Sangean 909X, 30ft RS ST-4 Discone Antenna, EF-SWL
  #2842 (permalink)
Old 05-09-2017, 11:06 AM
medic29's Avatar
Mine just has the regular 1/8" audio jack, like a headphone jack. I use a standard Mono jumper cord between the scanner and laptop. You may try using a different cord.
Rick Rogers, RN, EMT-P
  #2843 (permalink)
Old 05-09-2017, 11:11 AM
medic29's Avatar
Yeah, I just searched and read that forum. Just use a regular Mono audio cable and it will work just fine.
  #2844 (permalink)
Old 05-09-2017, 1:49 PM
nyair1's Avatar
Are you just running one radio? Im going to try and mess with it again tonite
Chris
Western NY
  #2845 (permalink)
Old 05-09-2017, 3:23 PM
medic29's Avatar
Yes, just connecting one scanner to one computer.
  #2846 (permalink)
Old 05-09-2017, 5:43 PM
buddrousa's Avatar
a $3 usb audio card will work just fine I am recording 8 fulltime and 1 parttime with PROSCAN.
Support your local FIRE & EMS. PRO197-106-18-107-668:PSR-410 X2: BC8500XLT 785d BCD436HP BCD536HPx2 BCT346 BCD996P2 x2 BCT15 BCT15X2 TRX-1 TRX-2 EFJ51SL MTX8250 Tk280 TK2180 MD380x4 NX5300 Buddy
  #2847 (permalink)
Old 05-09-2017, 8:28 PM
medic29's Avatar
I didn't know they made such an animal. Cool.
  #2848 (permalink)
Old 05-10-2017, 7:00 AM
WX4JCW's Avatar
Amazon
Sent from my iPhone using Tapatalk Pro
Jason WX4JCW EMD/FF/EMT RET
Like Johnny Cash's Song I've been everywhere man, ive been everywhere and monitored it
  #2849 (permalink)
Old 05-10-2017, 7:37 AM
buddrousa's Avatar
here is a link
USB2.0 External 7.1 Channel 3D Virtual Audio Sound Card Adapter PC | eBay
  #2850 (permalink)
Old 05-10-2017, 10:04 PM
nyair1's Avatar
Do you run those all off a usb hub??
Chris
Western NY
  #2851 (permalink)
Old 05-11-2017, 6:11 AM
buddrousa's Avatar
I am running a PC with 8 USB 2.0 ports and 2 USB 2.0 powered 7 port hubs with 3 9 pin serial ports for all my toys.
  #2852 (permalink)
Old 05-16-2017, 8:49 PM
Default How to record BC536HP audio through USB port
Hi,
I just made a few equipment moves in the shack and would now like to record audio from my BCD536HP over the radio / PC USB connections. I'm running the latest edition ProScan and currently using the mobo's built in sound card.
Any help appreciated. Thanks for taking the time to read this! 73
Richard
  #2853 (permalink)
Old 05-16-2017, 8:54 PM
buddrousa's Avatar
BCD536HP Wi-Fi Dongle Audio Setup
1. Insure the Scanner Type is set to BCD536HP
2. Go to Audio Control tab.
3. Click the Recorder, Source Client, etc... Depending on type of audio using.
4. Click the Input Sound Device combo box.
5. Choose URL.
6. Click the URL Setup button.
7. Enter the IP address of the scanner. Example --> rtsp://192.168.1.5/au:scanner.au
8. Click the Reconnect button.
9. If success, "TCP Not Connected" and "UDP Not Connected" messages should disappear and "Bytes RX"
increment.
  #2854 (permalink)
Old 05-17-2017, 9:34 AM
jonwienke's Avatar
I have a bug report.
When the Logging option "Use Tones For Frequency/Tone Matching Conventional Channels" is checked, traffic logging intermittently fails. Sometimes a transmission is completely ignored, especially if it is short. On longer transmissions, the mouse pointer may show an hourglass for a few seconds, and then the log is updated to show the transmission in progress.
This behavior does not occur if "Each Transmission New Row" is checked in the History Logging Tab.
My avatar means something.
  #2855 (permalink)
Old 05-21-2017, 7:32 PM
Metrofire31's Avatar
Default Programming issue
I have quickly become a ProScan fan and become more familiar with it with each use. I've been programming scanners - manually and with software - for 40 years but I've encountered an issue that has me stumped. I'm hoping I'm overlooking something simple but so far I'm out of solutions.
Recently, Proscan told me that the software "automatically" detects and uses the control channels while also downloading both CCs and Voice freqs. For some reason, my BCD996P2 only had the CCs loaded for all the P25 trunked systems. While travelling through Atlanta yesterday, the scanner all of a sudden stopped receiving the CC for ALL of the trunked systems I have programmed (approximately 20). When we reached our destination, I re-programmed them all and added the voice frequencies to each one. GUESS WHAT? On the way back to NC this afternoon, that modification had made ZERO effect at all. Which means, I've now tried the 996P2 with CC-Only and with All Freqs - and neither worked!
I've searched the software to see if there's a nuance I'm missing in the programming detail and I'm honestly STUMPED!! Anybody got a suggestion? I'm about ready to delete the codeplug and re-download the whole thing all over.
Metrofire31
Franklin, NC
WQIT636 (GMRS)
Metrofire31
WQIT636 - Atlanta
  #2856 (permalink)
Old 05-21-2017, 8:56 PM
ProScan's Avatar
Hi Metrofire31,
I'm real sure I didn't tell you the software (meaning ProScan I assume) detects and uses the CC. I may have said the scanner uses the CC frequencies only or something along that line. I don't know why the scanner stopped receiving; e.g. out of coverage area? Perhaps someone else would know the answer.
  #2857 (permalink)
Old Yesterday, 2:22 PM
Default Control channel only?
Thanks, ProScan! I certainly misquoted you, both in intent and specifics. Here is your exact reply to my earlier question. But I really need to know whether my Proscan codeplug should include ALL the Motorola-system's frequencies or would it work with only the Control Channels?
Originally Posted by ProScan View Post
Hi Metrofire31, Thanks for the compliments and glad you like ProScan.
On question 1, ProScan imports all the trunking frequencies from the RRDB regardless if some of the frequencies are control channel frequencies. The scanner operates in "Control Channel Only" mode on Motorola systems. It's by design.
On question 2, It sounds like you may not have a database file opened. If a database file is opened then the Tone-Out grid will show 10 rows than can be edited.
To open a database, go to the Database menu and click on Open or New but you probably know that since you are importing from the RRDB.
{edit} You are looking at the Fire Tone-Out grid under the Database tab and not the Fire Tone-Out Logging grid. Correct?
Metrofire31
WQIT636 - Atlanta
  #2858 (permalink)
Old Yesterday, 2:54 PM
Quote from Mark's easy to read
Control Channel Only Scanning - allows you to enter just the control channels to trunktrack a Motorola system and the scanner will find the voice channels.
I think all the late model Uniden will do CC ch only - I usually load all though. Only can be as issue if other sites use one of the same channels and you receive it (which should be out of range, yet can happen)
BCD536,Hp2(e),HP-1(e)x2, BC780, BCD996t ,BCD996P2, BCD325P2, Pro 2005, 2006(x2), Pro34,VR500,AT803,R5000and other RF capture devices
Tags
bc785d with proscan 6.6, logging, proscan
