Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
  #2901 (permalink)
Old 07-18-2017, 1:31 PM
ProScan's Avatar
Originally Posted by BCasto View Post
Bob, thanks a bunch. Fortunately I have a PC card that provides 2 Serial ports via RS232. One is being used for an older BC780XLT and the other is free since I retired another older scanner. As you know, many PCs ship without a serial port. However, I have 2 BCD996P2 scanners..
Use two USB to RS-232 converters and two null modem adapters and problem solved.
  #2902 (permalink)
Old 07-18-2017, 2:19 PM
I've had good luck with: Sabrent 6FT USB to RS-232 DB9 Serial 9 pin Adapter (Prolific PL2303) SBT-USC6K
$4 "Used" (Like New) from Amazon Warehouse.
  #2903 (permalink)
Old 07-19-2017, 10:56 AM
BCasto's Avatar
Never considered using the rear RS232 port, primarily because I thought it was dedicated to the GPS interface. Thanks for the great info.
  #2904 (permalink)
Old 07-19-2017, 8:16 PM
I'm having issues with Proscan loading, windows keeps saying that program is not responding. If I do get the program to load after logging in to web import from RR I get a time out issue or "program not responding"
I'm on Windows 10
  #2905 (permalink)
Old 07-20-2017, 8:59 PM
BCasto's Avatar
Oh snap, as my Aunt would say. Here is an update re. solving the Proscan / BCD996P2 disconnect when the PC goes into sleep mode.
Today I had the problem again and in a moment of frustration pulled the USB plug from the front of the BCD996P2. When I reinstalled it, the Proscan app returned to normal function. This prevented me from rebooting the system - a big deal to me. But I still need the RS232 cable rear attached to keep the app running when the PC is in sleep mode.
  #2906 (permalink)
Old 07-20-2017, 9:05 PM
ProScan's Avatar
I'm on Windows 10
I would do some troubleshooting such as installing ProScan in a new folder and see what happens. If normal then use the previous config file and restart to see if it does the same thing. Copy all the data files over to the new folder and restart to see if does the same thing.
  #2907 (permalink)
Old 07-20-2017, 11:43 PM
mike_s104's Avatar
Don't let the computer go to sleep. Change the power settings to high performance.
Sent from my SM-G930V using Tapatalk
  #2908 (permalink)
Old 07-21-2017, 3:46 PM
plaws's Avatar
Originally Posted by plaws View Post
Understood (at least after I actually downloaded the software). Not as useful to me if I can't replace Sentinel+Freescan+ARC780. The remote interface sure is nice, though.
When we last checked in, there was less-than-full support for the BCDx36HP scanners ...
Hi. Still looking to replace the various packages I use with The One True Scanner Control Package. I've since traded one of my 996XTs for a 996P2 and Freescan only sort-of supports the P2 radios. Still have my BC780XLT and still use it, on a rebanded system, even. So I'm really hoping Proscan has added full BCDx36HP support so I can use One Ring To Rule Them All.
As an aside ... the author of Freescan seems to have moved on like so many good radio software authors. bcTool was great, but the author moved on. AVC396 only supported one model and didn't manipulate channels but was great for monitoring - author moved on. So sad. I wish those authors would at least put their code under an open-source license so that others could tinker with the code. Alas ...
Peter Laws / N5UWY
I am not anti-social ... OK, a little ... but don't friend me, bro.
  #2909 (permalink)
Old 07-21-2017, 3:47 PM
milf's Avatar
Careful, I CAN hear you!
Nope.
Sent from my LG-K330 using Tapatalk
PRO-92, PRO-92B, PRO-96, BCD396XT, BCD436HP+DMR
APX6000XE
  #2910 (permalink)
Old 07-21-2017, 5:09 PM
Dear Bob!
Small but report.
Recording works improperly when PRI mode is ON and you're using Custom Search. ProScan mixes up filenames, adds other (from Custom Search freqs) voice traffic to PRIORITY channels files, and doubles some voice fragments in the same files.
How to reproduce. Create one conventional System with one Zone and one Group in it. Add a few conventional channels with heavy voice traffic, 2 channels are enough. Set PRI and PRI checkboxes for these channels. Enable Priority Scan in General settings and set PS Interval to 2 o 3 seconds. Program scanner and enable Custom search by QKs. Let it record many conversations and just listen to files from PRI channels.
Any BCT scanner affected. Windows 7 64 bit. Most current ProScan version (12.2). Each Transmission in New Row is enabled in recorder, if it matters.
  #2911 (permalink)
Old 07-23-2017, 5:00 PM
ProScan's Avatar
Default ProScan 12.3 Release
What's New In Version 12.3
  • Added - Lockout and Temp Lockout added to the Resume Scan / Search function.
  • Added - Mute all instances with a click of the Speaker Icon.
  • Added - Mute selected instances using the Sessions Manager.
  • Added - Metadata File option to read all lines, 1st line, & last line.
  • Changed - Notch Filter from 4000 to 6000 Hz maximum.
  • Fixed - Source Client Stream Name text box wasn't showing when set to Broadcastify.
  • Fixed - C-Ch Output wasn't showing P25 and DMR messages.
  • Fixed - Remote Scanner Over IP Client intermittent mp3 audio break up.
  • Fixed - Database FTO grid wasn't saving or uploading the Record column.
  • Fixed - When Sorting the History, UID, FTO, & Recorder logging grids using two columns to sort, the previous column sort direction wasn't working.
  • Many more small improvements.
ProScan supports the BCT15, BCT15X, BC250D, BC296D, BR330T, BC346XT, BC346XTC, BCD325P2, BCD396T, BCD396XT, BCD436HP, BCD536HP, BC780XLT, BC785D, BC796D, BCD996T, BCD996XT, & BCD996P2 scanners.
ProScan is the most powerful and feature rich scanner software in this world !!!
Made in the USA
  #2912 (permalink)
Old 07-23-2017, 5:40 PM
Homeboys-Scanna's Avatar
Just got the update and added a notch filter of 4800 Hz. This completely removes any EDACS "peap" at the end of transmissions and makes it sound so dang clean JUST like a professional radio. Thanks.
"Copy, 132 and Bush, cover's code 3."
  #2913 (permalink)
Old 07-24-2017, 10:50 AM
BCasto's Avatar
Is there any tool that can format the CCH output into it's different message parts?
  #2914 (permalink)
Old 07-27-2017, 1:17 AM
Magpie's Avatar
Great version Bob. I love the Lockout and Temp Lockout added to the Resume Scan / Search function.
I don't understand the Notch Filter function. Can someone please explain how to use it and what it does?
Mtia.
Henk aka Magpie
Diamond D-777 - Diamond X-50N | 5 x BCT15X - 1 x UBC780XLT | SSE Jim-HPF-0706a - CCW Multicoupler | Proscan 12.3 | Espresso
  #2915 (permalink)
Old 07-27-2017, 1:20 AM
milf's Avatar
Notches out unwanted ones etc. Like the end tones on EDACS comms or possibly MDC1200 tones
APX6000XE
  #2916 (permalink)
Old 07-27-2017, 2:08 PM
Magpie's Avatar
Thanks, will give it a try.
Henk aka Magpie
  #2917 (permalink)
Old 07-27-2017, 2:11 PM
Magpie's Avatar
Would it be possible Bob to shift the display part of the scanner a bit to the left to make space? It looks a bit untidy now, hope I make it clear enough
https://www.dropbox.com/s/8h5r3mc3lkp3q47/12.3.png?dl=0
Henk aka Magpie
  #2918 (permalink)
Old 07-27-2017, 2:33 PM
ProScan's Avatar
Negative however email may get a different result. Also specify scanner type.
  #2919 (permalink)
Old 07-27-2017, 3:13 PM
Magpie's Avatar
Disregard my request Bob. Ones running one can go back to regular layout where everything fits nicely.
Have briefje tested Custom Search with Auto Temp L/out set to ON. Works perfectly. Many thanks another great improvement in scanner monitoring
Henk aka Magpie
  #2920 (permalink)
Old 07-28-2017, 3:02 PM
plaws's Avatar
Anyone? Bueller?
Peter Laws / N5UWY
Tags
bc785d with proscan 6.6, logging, proscan, sleep, windows
