Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
  #3021 (permalink)
Old 10-09-2017, 1:01 PM
iMONITOR's Avatar
Originally Posted by kd7jfv View Post
On P25 Phase II system, the recorder is creating multiple audio files for each talkgroup as they bounce around on different frequencies for the system. Is there anyway to change the settings to record files based soley upon the talkgroup and ignore the frequency of the trunked sysstem?
Example:
TG 38151 transmits on 856.9375
TG 38151 transmits on 858.9375
Its creating two audio files. I have attached a screen shot.
Ben
Are you programing only the control channel(s), or the voice channels as well. Just a guess?
  #3022 (permalink)
ProScan's Avatar
Example:
Ben
Go to menu Options -> Recorder. The Custom Record Folder and Custom Filename Format text boxes Custom Formatters don't use %F for frequency and %FT for frequency / talk group. Use %TG in lieu of.
{edit} I just looked at your screenshot and don't see a frequency so Custom Filename Format text box not it but still check the Custom Record Folder.
Also uncheck the Each Transmission New Row option.
  #3023 (permalink)
Old 10-10-2017, 11:46 AM
kd7jfv's Avatar
This worked, removed %F and now its one file per talkgroup. Thanks!
  #3024 (permalink)
Old 10-12-2017, 6:14 PM
titothefixer's Avatar
Default Webserver stopping after 30 minutes
Every time I知 listening on my webserver for more than 30 minutes, it disconnects me. It happens whether I知 using a phone or a computer browser. Is there anything I can do to stop this? I知 running on Windows 10 with a BCD436HP
  #3025 (permalink)
Old 10-12-2017, 9:17 PM
buddrousa's Avatar
It may be your ISP
Support your local FIRE & EMS. PRO197-106-18-107-668:PSR-410 X2: BC8500XLT 785d BCD436HP BCD536HPx2 BCT346 BCD996P2 x2 BCT15 BCT15X2 TRX-1 TRX-2 EFJ51SL MTX8250 Tk280 TK2180 MD380x4 NX5300 Buddy
  #3026 (permalink)
Old 10-12-2017, 9:24 PM
Originally Posted by buddrousa View Post
It may be your ISP
I致e had a different program running for years and never had a problem. I switched to ProScan bc it has a lot more features. But I have a couple ideas to try and test that theory.
  #3027 (permalink)
Old 10-13-2017, 4:55 AM
ProScan's Avatar
Are you running AVG anti-virus software? That program interrupts TCP traffic.
  #3028 (permalink)
Old 10-13-2017, 11:15 AM
I am not running AVG. The only thing I use this computer for is Scanner programming and my feed. I just use Windows Defender
  #3029 (permalink)
Old 10-15-2017, 2:26 PM
Quickcall's Avatar
My Remote IP audio has been very choppy with sounds of different intermitent audio blips the past few days. Same thing on multiple computers. I have done the update. Tried different audio rates as well. Anyone else having this problem?
  #3030 (permalink)
Old 10-15-2017, 2:51 PM
Quickcall's Avatar
Quick update: I switched back to version 12.3 on both the client and sever computers and the issue has gone away. Must be the update.
  #3031 (permalink)
Old 10-15-2017, 8:15 PM
I have noticed this as well since 12.4. It's not a Wifi thing as it happens on RSOIP over a full ethernet LAN. I get short bursts of noise about every minute or so. Not a big deal but I have noticed it. (MP3 8000 16bit)
I also have had occassions when the RSOIP client connects there is no audio. This can be the client version or the full version running as client on startup, Restarting the client makes the audio return.
BCD996XT UBCD536PT UBCD436PT UBCD996T UBCD396XT UBCD396T UBC780XLT ProScan FreeScan PDW Scanner Recorder Pro AirSpy R2
Tags
bc785d with proscan 6.6, logging, proscan, sleep, windows
