Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
  #3201 (permalink)
Old 01-16-2018, 4:55 PM
Homeboys-Scanna's Avatar
Keep up the great work. This software is so well polished, it's remarkable.
"Copy, 132 and Bush, cover's code 3."
  #3202 (permalink)
Old 01-16-2018, 6:23 PM
ProScan's Avatar
Will do. Appreciate it.
  #3203 (permalink)
Old 01-17-2018, 1:44 PM
Nysff's Avatar
Default Feature Request
Can you possible add a feature to allow the ProScan Software to Detect, Display and Store MDC1200 Codes?
  #3204 (permalink)
Old 01-19-2018, 2:22 PM
iMONITOR's Avatar
Question
Hi Bob!
I know ProScan is licensed and can only be installed on one PC at a time. However, the system I use for controlling my scanner, uses a smaller monitor, mounted above normal eye level making it a little uncomfortable for viewing while programming/editing.
Is there anyway I could program/edit on one PC and run virtual control on another? I'm thinking maybe something like RealVNC or TeamViewer. Any suggestions?
  #3205 (permalink)
Old 01-19-2018, 2:33 PM
ProScan's Avatar
Originally Posted by iMONITOR View Post
Hi Bob!
Actually each license allows for activation on two computers. That was changed from one activation per license when RSOIP (Remote Scanner Over IP) came out. You could use RSOIP for remote programming provided the RSOIP on the client side is logged in as Control mode. That is all scanners except the BCDx36HP due to they need to be in Mass Storage mode and therefore no serial comms.
  #3206 (permalink)
Old 01-19-2018, 2:40 PM
iMONITOR's Avatar
Excellent, thank you! You always have an answer and respond quickly!
  #3207 (permalink)
Old 01-19-2018, 2:48 PM
Good to know, I didn't know you can program the using the remote mode.
The PC I am using as my "server" is not connected to a monitor or keyboard, so I just use TeamViewer to remote into the machine to program. It is also really handy to have available just in case something happens and you're out of town and your remote scanner stops functioning. Happened once to me and I when the power went out and shut the computer down. When it restarted ProScan wasn't running, I have since fixed that. Cheers.
  #3208 (permalink)
Old 01-22-2018, 3:49 PM
Default Is there an time prompt for auto resume/scan while logging?
Hi,
I've dug through this posting and the manual, but can't find if this feature is available. I'm switching from ARC396PRO for my BCD396T.
While logging, ARC has a setting to automatically resume scanning after a predetermined amount of time. For example, while scanning a frequency range, the ARC396PRO will log the hit, then resume scanning after five seconds whether or not the transmission is complete. I can't find a similar setting in ProScan, so letting the logging run unaided causes the scanner to hang for extended periods on long data bursts.
I've seen in the release notes that 10.5 added "Resume Scan / Search after predetermined amount of time", but I can't find the feature in the software.
Thanks for your help.
Uniden BCD396T, Uniden BC125AT, Radio Shack Pro-83, Uniden BC235XLT, Uniden BC278CLT, Uniden BC340CRS, Yaesu VR-500, Yaesu VR-120
  #3209 (permalink)
Old 01-22-2018, 4:38 PM
jonwienke's Avatar
It's there, but a bit buried.
In the Options dialog, General tab, check the "Show Mute Icon & Frequency, Tune, Jump Controls" box.
Click on a little white square in the upper-right corner of the main ProScan window until the Resume Scan/Search pulldown appears. I have mine set to 5 minutes, and temporary lockout.
  #3210 (permalink)
Old 01-22-2018, 4:52 PM
Perfect. Thanks very much.
  #3211 (permalink)
Old 01-26-2018, 8:22 AM
jasonhouk's Avatar
Version 12.6 I'm having an issue where the virtual scanner window when using scanner only view mode re positions itself out of frame/border after cycling though other windows/programs.
J
  #3212 (permalink)
Old 01-26-2018, 12:24 PM
ProScan's Avatar
J
I'll look at this before the next release.
  #3213 (permalink)
Old 01-27-2018, 7:54 AM
dave3825's Avatar
J
I get this also. For me, clicking view, then clicking on "scanner only" seems to reset it.
DMR436HP Br330T Pro 93 Pro 95
Arc330Pro ProScan Freescan BCDX36HP Easy Manual Id Tracker
  #3214 (permalink)
Old 01-27-2018, 9:16 AM
Default New Hard Drive Install
Hello
I have a new larger Hard Drive coming and would like to keep my ProScan Configuration if possible. If I do this
Just copy the ProScan.exe, all dll files, & ProScan_Manual.pdf files to a new folder
If you want the same options then copy ProScan.cfg file to the new folder. Post #2969
and then install ProScan into that folder will I be "good"
Thanks Andy
  #3215 (permalink)
Old 01-27-2018, 9:43 AM
ProScan's Avatar
Originally Posted by gootch View Post
Hello
Thanks Andy
The ProScan.cfg file contains the config so you want to copy that one along with the exe and dll files. It also depends on if you want to retain the Logging, Recordings, Broadcast Lockout for streaming, etc. I would copy the whole folder to the new drive to be safe.
  #3216 (permalink)
Old 01-27-2018, 9:51 AM
  #3217 (permalink)
Old 01-28-2018, 8:50 AM
jonwienke's Avatar
https://forums.radioreference.com/un...ice-types.html
The question there would be easily solved if the search/replace dialog allowed separate search and replace parameters--search for a Service Type, and replace the Alert Light setting when a match is found. Would that be difficult to do?
  #3218 (permalink)
Old 01-28-2018, 10:39 AM
ProScan's Avatar
J
I can't duplicate this problem. Can you send me an email so I can send you the latest for testing this problem.
  #3219 (permalink)
Old 01-28-2018, 2:00 PM
ProScan's Avatar
Are you talking about something like this?
  #3220 (permalink)
Old 01-29-2018, 4:58 AM
ProScan's Avatar
Good suggestion. Got it done.
Tags
bc785d with proscan 6.6, logging, proscan, sleep, windows
