Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
  #3261 (permalink)
Old 02-17-2018, 11:36 AM
ProScan's Avatar
Originally Posted by n8jsw View Post
Just a quick question? Why is it that when I open Proscan and i have 12.7 it says password must contain a value but when i hit ok it then opens all the way
You probably have the Source Client Auto Connect set on in the Start Up options and the Source Client password box is blank. Turn off the Source Client Auto Connect located in the menu - Options -> Start Up.
  #3262 (permalink)
Old 02-18-2018, 8:51 AM
n8jsw's Avatar
That worked thanks alot. Love it alot
N8JSW
Icom Ic-2350H, Uniden BCD396XT,Uniden 996P2
  #3263 (permalink)
Old 02-18-2018, 3:03 PM
BCasto's Avatar
Default Old versions - can I delete them?
Bob, since licensing ProScan, I have kept folders of the old version every time I install the new version. I now have many folders. Is it OK to delete the old versions? I am not sure where the license key or activation key is stored and certainly don't want to mess up my license.
And once again, you have built a wonderful product. -- Brian
  #3264 (permalink)
Old 02-18-2018, 4:13 PM
ProScan's Avatar
Go ahead, delete the old folders.
  #3265 (permalink)
Old Yesterday, 2:41 PM
BCasto's Avatar
Default Upload Speed
Bob, it takes me 18 Mins 45 Seconds to upload a file to my BCD996P2. Can you tell me if that is normal?
I am deleting all files before uploading. The file has 58 sites, 432 Groups, and 8128 Channels. The file size is 665KB.
The scanner is attached by the new USB cable. Both the PC and Scanner Com Port speed is set to 115,200. The other PC Com Port settings are: 8 Data Bits, Parity NONE, Stop Bit 1, Flow Control NONE, FIFO Buffers set to HIGH. The Driver is PROLIFIC V 3.2.0.0.
The PC is several years old running Windows 7 PE.
Just wanted to know if there is a way to have to go much faster. Thank you..
  #3266 (permalink)
Old Yesterday, 4:02 PM
ProScan's Avatar
That sounds about right.
Tags
bc785d with proscan 6.6, logging, proscan, sleep, windows
