Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
  #3421 (permalink)
Old 04-14-2018, 9:24 PM
ProScan's Avatar
Originally Posted by buddrousa View Post
Bob I am missing something having trouble buying 2nd lic for PC 3 and 4 says user name taken.
If you can chose a different Reg Name for each purchase. I can upon request, merge each purchase into a single purchase with one Reg Name..
  #3422 (permalink)
Old 04-15-2018, 7:36 AM
eaf1956's Avatar
Bob did this for my two licenses and all it well!
Current scanners:BCD 996XT,BCD996P2
BCD536HP (2) and a SDS 100
Ham Gear: Icom 7000, U82, V82, V8, IC 2820, MD2017, Vertex Standard EVX 539, MD 9600, CS 800D, Yaesu FTM100 DR and a YAESU FTM400DR
  #3423 (permalink)
Old 04-17-2018, 12:30 AM
Should the Baud Rate in Device Manager for the Uniden Serial Port be set to match the scannerís & Proscanís baud rates?
At present, both the scanner and Proscan are set at 115,200 but Device Manager Shows that the Uniden Serial Portís baud rate is set to 9600. It can be set to 115,200 too.
  #3424 (permalink)
Old 04-17-2018, 12:37 AM
In all my years, I've never had to change the baud rate in device manager.
I think it may have mattered in old Win 3 or 3.11.
I'm not even sure what the device manager baud rate setting does in modern day windows unless it is a compatibility thing maybe.
I have a dozen or so instances of ProScan running and just setting the radios baud and proscan so they match was all I ever needed to do.
  #3425 (permalink)
Old 04-17-2018, 12:46 AM
ProScan's Avatar
Should the Baud Rate in Device Manager for the Uniden Serial Port be set to match the scanner’s & Proscan’s baud rates?
At present, both the scanner and Proscan are set at 115,200 but Device Manager Shows that the Uniden Serial Port’s baud rate is set to 9600. It can be set to 115,200 too.
The Device Manager Port Settings baud rate doesn't matter. That's for legacy Modems.
  #3426 (permalink)
Old 04-17-2018, 1:03 AM
Thanks for the help guys, I will not change it.
  #3427 (permalink)
Old 04-22-2018, 9:47 PM
How do I copy the History Logging Data from ProScan on my laptop to ProScan on my desktop? Transferring the ProScan file in Drive C does not transfer the history logging data.
  #3428 (permalink)
Old 04-23-2018, 1:45 AM
ProScan's Avatar
1. Make sure ProScan is not running on the desktop else the "History Data.txt" file will be overwritten with different data when ProScan shuts down.
2. Copy the "History Data.txt" file located in the ProScan folder.
3. Restart ProScan, ProScan will read the "History Data.txt" file and populate the logging grid.
  #3429 (permalink)
Old 04-23-2018, 9:08 AM
I do not see a "History Data txt" file in the ProScan folder in C/ Program Files x36/ ProScan folder. Where would this file be? I searched the entire C drive for it yesterday but never found it.
  #3430 (permalink)
Old 04-23-2018, 9:25 AM
ProScan's Avatar
From the proscan.org FAQ page:
Q: I can't find the config file or the logging files.
A: If ProScan is installed in the Program Files(x86) folder AND running 64 bit OS AND not running ProScan in admin mode then Windows puts all program generated files in the VirtualStore folder located at C:\Users\[user]\AppData\Local\VirtualStore\Program Files (x86)\ProScan
An easy way to get there is go to the Test & Extra tab and click on the "Windows File Explorer Application Data Folder" button
  #3431 (permalink)
Old 04-23-2018, 10:25 AM
Program Files (x36) is the default location that ProScan installs. I am now more lost than before. Can't find Test & Extra tab or any of the files. Is there a video for this or more detailed instructions? In every other scanner, ham and music programs I own, transferring files from one computer to another is very easy. I would like to see all my loggings history load when I start ProScan on my desktop like on my laptop.
  #3432 (permalink)
Old 04-23-2018, 11:06 AM
smason's Avatar
Here is a screenshot
Lots of radios, not enough antennas...
  #3433 (permalink)
Old 04-23-2018, 11:13 AM
ProScan's Avatar
The Test & Extra tab is the far right tab.
You can't find the VirtualStore folder or the files inside?
Negative.
If the program was elevated to Admin or the program is installed in another folder besides Program Files (x86) then the program generated data files will be in the ProScan folder. That's the way Windows work on 64 bit systems on non elevated to Admin programs in the Program Files (x86) folder.
{edit} Thanks smason for the screenshot.
  #3434 (permalink)
Old 04-23-2018, 12:39 PM
Mission Accomplished. Thanks For The Guidance. The More I Learn About ProScan, The More I Like It.
  #3435 (permalink)
Old 04-23-2018, 12:52 PM
iMONITOR's Avatar
And the more you like it, the more you'll learn about it! The new features and capabilities just keep on coming!
  #3436 (permalink)
Old 04-23-2018, 2:07 PM
NYRHKY94's Avatar
Agree with iMonitor. And the "post-sale" support from the author (Bob) is exemplary IMO. I've gotten all of my investment back from the 2 licenses over the years and then some :-)
BCD536HP/BCD436HP/BCD996P2/BCD325P2/BCD996XT/BCT15X/PRO-197/PSR-600
  #3437 (permalink)
Old 04-23-2018, 4:12 PM
I'm 3 days new with Proscan - demo, looks really slick, I'm trying to like it. Now for a really dumb question, mind you - like someone else stated, I'm drinking this with a fire hose. Radio - BCD436HP, I bring up the radio menu by clicking on the "MENU" button on the pictured radio, I can scroll thru the menu options with my mouse wheel, -how the heck do you select and item in the menu? On the radio of course you just press down on the knob on the top.
I have clicked and pressed every button on that screen, but the right one. I've been at this for over 2 hours.
Whats the secret?
OK, I just figured it out, I guess you have to post the question and then right after things come to you.
" E/YES" button
  #3438 (permalink)
Old 04-23-2018, 4:17 PM
mule1075's Avatar
Press the enter E key.
Uniden BCD536HPx2/250D Motorola HT1000/GM360
  #3439 (permalink)
Old 04-23-2018, 4:36 PM
ProScan's Avatar
Whats the secret?
" E/YES" button
Double clicking the big knob will also do it. A single click will get the focus so it could be turned CCW or CW with the mouse or keyboard.
  #3440 (permalink)
Old 04-23-2018, 5:05 PM
Thanks Guys
Tags
bc785d with proscan 6.6, logging, proscan, sleep, windows
