Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
  #3501 (permalink)
Old 05-15-2018, 9:35 AM
gskroll's Avatar
Originally Posted by ProScan View Post
Don't select "Other File". Select Database. After clicking the Copy button, a dialog will appear prompting which existing Favorites list to copy to. Check the "New Favorite List" check box to create a new favorite list.
Thanks Bob - I was able to take only the channels & talkgroups that have been active over the last 48 hours and create “tailored” Favorite Lists omitting Systems that have not seen activity during that period.
Maybe a future enhancement could use the name fields from the history log to populate the names in the new Systems, Departments, and Channel/Talkgroups?
Thanks for your help. As others have said - there is a lot of capability in ProScan and as a new user, I have a lot to learn/discover.
  #3502 (permalink)
Old 05-17-2018, 12:35 PM
Question Where do I find settings to change text tag justifications?
Hiya folks,
Just playing around with ProScan for the first time.
Is there an easy place to change text tag justification (justified left, centered, etc.)? Preferably all at once (ie; all tags within a group).
I find it easier to center justify all my conventional channel tags and left justify (and lower case) all my TG IDs to know what I am listening to on a quick glance.
I was able to do it in all iterations of the butel software I've owned but can't seem to find a similar option in ProScan.
Still learning the lay of the land within the software so be gentle.
Thank you!
Ted Pendergast
Cambridge, Massachusetts, USA
FIRST DUE! Fireground Photography -- http://www.firstduephotos.com
  #3503 (permalink)
Old 05-17-2018, 3:36 PM
ProScan's Avatar
Originally Posted by tede911 View Post
Hiya folks,
Thank you!
It's located in the menu Utilities - Update Text Tags.
  #3504 (permalink)
Old 05-17-2018, 4:15 PM
Excellent! Thank you
Ted Pendergast
  #3505 (permalink)
Old 05-18-2018, 6:38 AM
jonwienke's Avatar
When you click on the Audio Control tab in Normal Display mode, the scanner display disappears. It is visible with every other tab? Is there a reason for that, or can the next release not disappear the scanner display when on the Audio Control tab?
  #3506 (permalink)
Old 05-18-2018, 7:32 AM
ProScan's Avatar
Are you on the Monitor & Test tab? If so, that's by design as a lot of controls needs to be displayed on the same subtab. Click the Recorder, Web Server, RSOIP, or Audio Scope subtab will bring the display back.
  #3507 (permalink)
Old 05-18-2018, 7:40 AM
jonwienke's Avatar
There is very little difference between the RSOIP and M&T tabs--mainly the Loopback checkbox and the Level radio buttons. Is the difference based on screen space, or performance?
  #3508 (permalink)
Old 05-18-2018, 7:44 AM
ProScan's Avatar
No, It's based on the amount of controls. Increase the height and you shall see the tone generator controls, Level meters and Level indicator options.
  #3509 (permalink)
Old Yesterday, 9:54 PM
iMONITOR's Avatar
Question Limit to how long you can run History Log,and how big it can be?
I've been running ProScan 12.12 with the History Log open. Is there a limit to how long you can run the History Log, or how big it can be? A couple of times ProScan has locked up after running the History Log 24/7 for a few days. I know that's a lot to ask, and it's not even necessary.
I have a Dell T7810 Precision Workstation with dual 8-core Intel E5-2609v4 1.7GHz Intel processors and 32GB of RAM, 500GB Samsung EVO SSD, Windows 10 Pro 64-bit, linked to a BCD536HP scanner.
I upgraded to v 12.13 and will try it with that version and see if there is a difference.
  #3510 (permalink)
Old Yesterday, 10:08 PM
buddrousa's Avatar
I have a history log over a year long.
Support your local FIRE & EMS. PRO197-18-107-668:PSR-410 X2: BC8500XLT 785d BCD436HP BCD536HPx3 BCT346 BCD996P2 x3 BCT15x2 BCT15X2 TRX-1 TRX-2 EFJ51SL MTX8250 Tk280 TK2180 MD380x4 NX5300 NX5200 Buddy
  #3511 (permalink)
Old Yesterday, 11:20 PM
ProScan's Avatar
Default STS100
First look. STS100 support should be ready approx. a month or two after the retailers start selling them and I get a hold of one.
  #3512 (permalink)
Old Today, 12:30 AM
iMONITOR's Avatar
Thumbs up
WOW!
I was just getting read to go to bed...now I'm wide awake! Nice, looks promising!
  #3513 (permalink)
Old Today, 1:34 AM
jonwienke's Avatar
I don't mean to be pedantic, but isn't it the SDS-100?
  #3514 (permalink)
Old Today, 5:30 AM
Ability to change colors, write to the config file and save various color sets would be a nice feature (FUTURE).
BCD536,Hp2(e),HP-1(e)x2, BC780, BCD996t ,BCD996P2, BCD325P2, Pro 2005, 2006(x2), Pro34,VR500,AT803,R5000and other RF capture devices
  #3515 (permalink)
Old Today, 6:31 AM
iMONITOR's Avatar
No error on his part. The SDS is the new handheld we've all seen here. The STS is the new much larger base scanner we've been hoping for!
Just kidding!
Tags
bc785d with proscan 6.6, logging, proscan, sleep, windows
