Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
  #3681 (permalink)
Old 06-20-2018, 4:20 PM
jonwienke's Avatar
Options menu \ Recording tab \ Recordings Location button
  #3682 (permalink)
Old 06-20-2018, 4:26 PM
ProScan's Avatar
Originally Posted by KJ4LZM View Post
Where are the Recording files stored? I have looked in my ProScan file folder bit I can see them.
From the Frequently Asked Questions page
Q: I can't find the config file or the logging files.
A: If ProScan is installed in the Program Files(x86) folder AND running 64 bit OS AND not running ProScan in admin mode then Windows puts all program generated files in the VirtualStore folder located at C:\Users\[user]\AppData\Local\VirtualStore\Program Files (x86)\ProScan
To get there quickly, go to the Test & Extra tab and click on the File Explorer button.
  #3683 (permalink)
Old 06-20-2018, 4:43 PM
Thanks, I got them!
Nothing clears the mind like a lack of alternatives!
  #3684 (permalink)
Old 06-20-2018, 9:30 PM
Possible bug:
When using the google maps and update, then select favorite and systems drop down menu, the system names have to be justified left in order for it to load correctly. Any setting other then that will load a blank map.
Tim
  #3685 (permalink)
Old 06-20-2018, 9:40 PM
ProScan's Avatar
Originally Posted by timkilbride View Post
Possible bug:
Tim
I'll look at that, thanks.
  #3686 (permalink)
Old 06-20-2018, 11:08 PM
ProScan's Avatar
Originally Posted by wm8s View Post
On the "UID Logging" tab on my SDS100, am I the only one whose "UID Number" column is blank for every entry? "UID Before Lookup" contains the correct tag, but the #s are all blank. Am I doing something stupid? [It works fine on my BCD536HP.]
...R
It appears to be a firmware bug with the SDS100
Reported
https://forums.radioreference.com/un...ml#post2953128
  #3687 (permalink)
Old Yesterday, 4:16 PM
wm8s's Avatar
Reported
I saw your question to Paul about the GSI response on the other thread; I'll follow it there.
I got 0 responses to my other question re: whether it's possible to configure ProScan to record audio more or less the same way that the scanner itself does, i.e., one audio recording file per PTT. On a trunked system, currently if a conversation between RID 1 and RID 2 is recorded, even if I put the %U1 in the filename, the whole conversation gets recorded under whichever RID initiated the conversation. Any thoughts?
Thanks!
...R
  #3688 (permalink)
Old Yesterday, 7:45 PM
ProScan's Avatar
Thanks!
...R
Yes one file per transmission is possible. Check the checkbox "Each Transmission one Row".
On the RID or UID, It's not recommended to use with the Recording File format. Ther UID may never arrive or arrive late.
Tags
bc785d with proscan 6.6, logging, proscan, sleep, windows
