Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
  #3761 (permalink)
Old 08-09-2018, 4:52 PM
ProScan's Avatar
Having a an issue with Proscan recordings as viewed on the BCD536HP Proscan scanner display. After so many seconds a recording will "reset" itself and start recording again. I was recording a milair frequency and it had reached somewhere around 45 seconds. When I looked again the initial recording was gone and a new one was in its place showing a new start time and showing about 8 seconds of recording. On my C:\ drive in the Proscan\Recordings folder all the original transmissions are still there and playable. Did I change something inadvertently? Thanks
I was able to watch when it happened again. As soon as the recording hit 1 minute it disappeared. Then popped up again as a new recording. I have "Active row in view" set. "Activity" is set. In the Options tab I see that Delete < 2sec is checked. Max recording time is set to "none". Recordings auto delete is set at 30 days.
Does it only happen on one channel?
Did it just start happening?
Does it do it at the one minute mark each time?
Try setting the Max. Recording option to some value and back to None.
I haven't heard of this before and don't know what would cause this.
  #3762 (permalink)
Old Yesterday, 11:51 AM
Monitoring a VHF P-25 channel with a 2 digit NAC. I can't get Proscan to log the NAC, no problem with 3 digit NAC's only the 2 digit, either in a NAC search or a programmed NAC.
Any thoughts? Anyone else?
Kenny
  #3763 (permalink)
Old Yesterday, 2:58 PM
scan-pa's Avatar
RRDB Admin
What is the user, frequency and nac?
Sent from my SM-G935V using Tapatalk
Peter
Scan-Pa
SC PA RRDB Admin
KC3HIO - HAM
WQXU562 - GMRS Cornwall "600" Rptr.
Admiral - 11m
  #3764 (permalink)
Old Yesterday, 3:15 PM
User and Freq doesn't really matter. the NAC is $70
Kenny
Tags
bc785d with proscan 6.6, logging, proscan, sleep, windows
