Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
  #21 (permalink)
Old 03-10-2008, 5:26 PM
ProScan's Avatar
Originally Posted by mike_s104
Thanks Bob...
Build 3 names the files like I was looking for. (folders per each day would help organize, but I'm not complaining.) works beautifully!!
if I do the folders suggestion, I may make the option something like this.
Organize Recordings In Sub Folders By:
Date
Frequency / TGID
Date - Frequency / TGID
Frequency / TGID - Date
Bob
  #22 (permalink)
Old 03-14-2008, 8:32 PM
mike_s104's Avatar
Date
Frequency / TGID
Bob
that would be perfect. :-) I still need to pay for it. I've been very busy and the demo is working wonderfully. I'm able to stream at work and keep an ear on what's going on at home. thanks again for taking suggestions and making a great app. :-)
was the option for MP3 compression removed?
  #23 (permalink)
Old 03-24-2008, 6:55 AM
mike_s104's Avatar
was the feature/option to convert the recorded wav files to MP3s removed?
  #24 (permalink)
Old 03-24-2008, 7:24 AM
ProScan's Avatar
Yes and I also put that on my web site in the Version History. There may be some licensing issues involved.
  #25 (permalink)
Old 03-24-2008, 7:51 PM
mike_s104's Avatar
Thanks. I didn't notice it on the site. :-) Could there be an option to use an external application like in Exact Audio Copy where the use will need to provide LAME?
  #26 (permalink)
Old 03-25-2008, 1:33 PM
ProScan's Avatar
I'm not planning to do anything like that but will keep it in mind. Next up is adding more scanners.
Bob
www.proscan.org
  #27 (permalink)
Old 05-01-2008, 6:06 AM
ProScan's Avatar
Atten Modes - Can this sticky title be changed to "Offical ProScan Software Thread"?
ProScan Ver 1.7 Build 4 is out. I'm committed in making this the best Computer Aided Scanning software.
ProScan supports the BCD996T, BC15T, BC780XLT, BC785D, BC796D, BC250D, and BC296D scanners.
The Scanner Over IP feature has been redone with the Point-To-Point mode eliminated and the Multicast mode now can accept multiple Control Client connections.
www.proscan.org
Bob
  #28 (permalink)
Old 05-04-2008, 12:16 PM
WX4JCW's Avatar
Awesome Job Bob, I registered mine and use it constantly, keep it up
Jason WX4JCW EMD/FF/EMT RET
Like Johnny Cash's Song I've been everywhere man, ive been everywhere and monitored it
SDS100,XPR7550,SDR
  #29 (permalink)
Old 05-04-2008, 6:21 PM
mike_s104's Avatar
www.proscan.org
Bob
Great update with the recording folders!! :-) Thank you.
  #30 (permalink)
Old 05-17-2008, 3:38 PM
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
Would ProScan work on a UBC3300XLT which is basically the European version of the BC250D?
Pro-43 / Pro-96 / BCT8 / BC898T / UBC3300XLT
  #31 (permalink)
Old 05-17-2008, 7:22 PM
ICP963's Avatar
ProScan has a 30 day free trial, download it and try it. If it does work with the UBC3300XLT I am sure you will like it. I am feeding with a 250D and ProScan and love it.
Roy Schahrer ICP963
e-mail k8x815@cox.net
  #32 (permalink)
Old 07-04-2008, 9:49 PM
mike_s104's Avatar
Default Build 5
When should we expect build 5 to come out?
  #33 (permalink)
Old 07-05-2008, 10:49 PM
ProScan's Avatar
Next version 1.7 Build 5 is just about done. It should be out approx. July 18.
Bob
Taking scanning to the next level!
bob@proscan.org
  #34 (permalink)
Old 08-01-2008, 12:08 PM
ProScan's Avatar
Default ProScan Version 1.7 Build 5 is out
I have finally just released ProScan Version 1.7 Build 5. The BCD396T scanner has been added. The Remote Scanner Over IP has been made more stable with the intermittent disconnects at a minimum. Also many small improvements have been made.
Most Popular & Feature-Rich Scanner Software For The Uniden's
ProScan - RadioFeed Home Page
bob@proscan.org
  #35 (permalink)
Old 08-17-2008, 4:57 PM
slypx's Avatar
Quebec DB Adm
Question ProScan and BC780XLT
Just bought the software and used it with my 396 and 996 and it works fine.
When I used it with my BC780XLT, I don't seem to be able to control the volume ??
It is just me or I'm blind don't find the volume control ?????????
Slypx
Quebec DB Admin
BCD396XT | PSR600 | PSR500C | BC780XLT | PRO2006 | PRO2046 |
  #36 (permalink)
Old 08-17-2008, 7:44 PM
ProScan's Avatar
The 780 volume can't be controlled from software. No protocol command to do it and therefore there's no virtual volume control on ProScan. I suspect that the scanner volume control is wired to the amp/speaker section unlike the newer DMA models with the volume control tied to the processor probably via A/D and I/O.
bob@proscan.org
  #37 (permalink)
Old 08-17-2008, 7:59 PM
slypx's Avatar
Quebec DB Adm
OK thanks - Finally I'm sure I'm not blind !
Thanks for a fast reply !
Slypx
Quebec DB Admin
  #38 (permalink)
Old 08-18-2008, 9:17 AM
KI4LIV's Avatar
Originally Posted by FPO703 View Post
Why not include the BCD396T as well since it's the same as the BCD996T?
I've used apps for the BCD396T on my BR330T as well - would love to see support for the 330T!
--Light is faster than sound... Perhaps that explains why some people appear to be intelligent - until we hear them speak!
  #39 (permalink)
Old 08-18-2008, 11:35 AM
ProScan's Avatar
The BR330T and BC246T will be next.
BTW in your last post, you quoted an old message. ProScan now supports the BCD396T.
bob@proscan.org
  #40 (permalink)
Old 08-23-2008, 12:12 PM
KN4QHZ's Avatar
Default The Best...
By far one of the best S/W packages available. Keep up the excellent work and support
BCD536HP
WR-G31DDC 'EXCALIBUR'
D-130 OMNI - VHF/UHF Antenna
75FT LONGWIRE - HF Antenna
Tags
bc785d with proscan 6.6, bdc325p2, logging, proscan, proscan 14.3, sleep, windows
