Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
  #821 (permalink)
Old 02-27-2012, 5:25 PM
Bob,
Thanks, I have done that and I did it again to make sure. no change.
the windows device mngr show the com port 19.
I changed the scanner baud rate back to 115200 front and back.
I changed the ProScan settings to com port 19 and baud 115200.
no change, still shows "no response"
I re booted everything, no change.
what next?
thanks again,
jb
  #822 (permalink)
Old 02-27-2012, 7:21 PM
ProScan's Avatar
Originally Posted by SHAKEY View Post
Bob,
what next?
thanks again,
jb
You are using the rear port? correct? Is the null modem adapter OK? Pins 2 & 3 reversed. Have you tried the front port?
  #823 (permalink)
Old 02-27-2012, 7:40 PM
I think that's it, the OP said he had a "gender" changer but no mention of a NULL modem adapter.
  #824 (permalink)
Old 02-27-2012, 7:48 PM
ProScan's Avatar
You're right.
  #825 (permalink)
Old 02-27-2012, 8:06 PM
ak4fn's Avatar
$1.43 DB9, F/F, Null Modem Mini Type | Null Modem DB9 Mini Type Adapters
BCD536HP BCD436HP BCD996XT BCD396XT BCT15X BC780XLT Pro-668 Pro-197 Pro-106 Pro-2096
  #826 (permalink)
Old 02-27-2012, 8:14 PM
Well,
If I need a NULL modem adapt then that is the problem. I guess I missed that somewhere.
So to make sure I understand, I need the serial to USB then the null modem also.
Do you still need the null modem if you use the uniden USB1 cable?
And I didn't need (or don't need) the null modem for the 780xlt?
Thanks again
jb
  #827 (permalink)
Old 02-27-2012, 8:22 PM
ak4fn's Avatar
So to make sure I understand, I need the serial to USB then the null modem also. Yes, but with the link I posted you should be able to ditch the gender adapter you are using.
Do you still need the null modem if you use the uniden USB1 cable? No
And I didn't need (or don't need) the null modem for the 780xlt? I don't remember I have had it so long
And if you have a comport you don't need the usb to serial adapter (and it is so much simpler) Just get this cable and it is one less thing to have go bad or give you problems
  #828 (permalink)
Old 02-27-2012, 8:26 PM
ProScan's Avatar
Well,
You need a serial to USB converter if your computer does not have a RS-232 serial port.
No. Null modem adapters needed for rear port only. The Uniden USB1 cable is for the front port.
Do you have a USB1 cable? Use that.
That's correct.
Thanks again
jb
  #829 (permalink)
Old 02-27-2012, 8:56 PM
The front port with the cable that came with it connected to the USB to serial cable works!
Thanks for your help.
Jb
  #830 (permalink)
Old 02-27-2012, 9:01 PM
ProScan's Avatar
Jb
Not a problem. Good to hear.
  #831 (permalink)
Old 03-25-2012, 6:31 AM
schs448's Avatar
I am running Proscan successfully on my Aspire One netbook
My only issue is the inability to view and use the buttons at the bottom of each window - no matter what I seem to do the bottom of each window is clipped
Anyone have a workaround for this?
  #832 (permalink)
Old 03-25-2012, 6:56 AM
Wiki Admin Emeritus
Change your screen resolution? Mike
  #833 (permalink)
Old 03-26-2012, 7:25 AM
schs448's Avatar
Thanks - Tried that, but even at max resolution it doesn't help
  #834 (permalink)
Old 03-26-2012, 8:12 AM
mike_s104's Avatar
You stated you are using it on a
"netbook". What make, model and screen size is it? If it has an output for a TV or monitor, have you tries either of those?
Sent from my ADR6400L using Tapatalk
  #835 (permalink)
Old 03-26-2012, 1:25 PM
ak4fn's Avatar
I use a program called AutoHotKey and use this script that allows you to "grab" the window and move it, by holding down "ALT key" and your "left mouse button" anywhere on the window you want to move, so you would be able to move proscan and be able to see all the buttons.
  #836 (permalink)
Old 03-26-2012, 2:51 PM
mancow's Avatar
I have one of those, you have to auto hide the toolbar.
  #837 (permalink)
Old 03-27-2012, 6:40 AM
schs448's Avatar
Thanks - will give those tips a try
  #838 (permalink)
Old 04-16-2012, 12:30 PM
Huh. Do I need a null modem cable for my BC796D as well?
  #839 (permalink)
Old 04-16-2012, 7:11 PM
ProScan's Avatar
Negative. It's only needed with the DMA's rear port so the port can connect to a GPS device.
  #840 (permalink)
Old 04-16-2012, 8:32 PM
Sweet. I'll just order a gender changer then.
Tags
bc785d with proscan 6.6, logging, proscan, sleep, windows
