Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
  #1081 (permalink)
Old 07-12-2013, 7:29 PM
kbod9633's Avatar
Default re: Official Software Thread
What email address can I use to have my
Pin resent to me I am a registered owner of pros can
Installed on laptop it crashed reloaded windows hard drive went out so lost my info
Sent from my DROID RAZR HD using Tapatalk 2
Bob
BCD536HP, BCD436HP, BCD996XT, 2 TRX-1's , PRO-96
  #1082 (permalink)
Old 07-12-2013, 9:53 PM
ProScan's Avatar
bob@proscan.org, support@proscan.org, or register@proscan.org
  #1083 (permalink)
Old 07-12-2013, 10:08 PM
kbod9633's Avatar
Originally Posted by ProScan View Post
Email just sent thank you
Bob
  #1084 (permalink)
Old 07-14-2013, 11:03 AM
kbod9633's Avatar
I sent it yo the support address still no response
Bob
  #1085 (permalink)
Old 07-14-2013, 12:35 PM
alwayslookin's Avatar
I would wait till at least Monday afternoon Bob is usally very good at responding to emails and to post here and at the Proscan website. Just my 2 cents.
  #1086 (permalink)
Old 07-16-2013, 6:18 PM
nyair1's Avatar
Default Proscan remote setup
I have been reading through the instructions on how to setup my radio to braodcast over the internet. I don't know alot about this and seem to be having a problem with the web server setup. I picked a port number and tried to test the connection per the instructions but it won't bring up my local ip when you click the get ip box. It does show my outside ip but i can't figure out what is going on. I have tried a few different port numbers and still no luck?? I would like to be able to remotely listen to my radio at work or in my house with my laptop using the client proscan. Is there anymore basic instructions?? I don't know much about this. Thanks
Chris
Western NY
Uniden 996XT(2), 15X(2), 396XT, Sangean 909X, 30ft RS ST-4 Discone Antenna, EF-SWL
  #1087 (permalink)
Old 07-16-2013, 8:09 PM
ak4fn's Avatar
Have you forwarded the port in your router?
BCD536HP BCD436HP BCD996XT BCD396XT BCT15X BC780XLT Pro-668 Pro-197 Pro-106 Pro-2096
  #1088 (permalink)
Old 07-17-2013, 8:55 AM
ProScan's Avatar
When you say "client". Do you mean the Remote Scanner Over IP Client? That is for connecting to the Remote Scanner Over IP Server. You can use the Web Server or Remote Scanner Over IP Server. Setup is the same. Web Server is for Web browsers to connect.
Same question that ak4fn asked...Have you forwarded the port in your router?
  #1089 (permalink)
Old 07-22-2013, 10:00 PM
rmosier's Avatar
I'm using version the latest version. Some time after I start the program (an hour or two sometimes) it's CPU usage will climb to 90%. What's that all about?
Mt. Olive (Morris County), NJ
Bearcat IV, AR1000, AR8200 MK1 EU (Non-Blocked), BCD396T & BCD396XT
  #1090 (permalink)
Old 07-22-2013, 10:23 PM
ProScan's Avatar
I'm working on this with a user via email. Once resolved, I will send out an update.
  #1091 (permalink)
Old 07-23-2013, 11:44 PM
rmosier's Avatar
Cool. Thanks for the reply too.
  #1092 (permalink)
Old 07-24-2013, 9:43 PM
nyair1's Avatar
How do i go about that?
Chris
Western NY
  #1093 (permalink)
Old 07-25-2013, 12:19 AM
You need to go into your router settings and setup a port to be forwarded by typing your routers ip address in your browser should be something like 192.168.1.1 type in user name and password some default user name is admin and the password may be the same, check with your routers website and that should tell you. then go to port forwarding tab and setup a port to be used. Hope this helps.
  #1094 (permalink)
Old 07-25-2013, 6:44 AM
ProScan's Avatar
What's the make and model of the router?
Are you trying to get the Remote Scanner Over IP Client or Web Server to work?
Before you setup the router Port Forwarding, you should test for connectivity locally (or on the same machine). Locally the IP address starts with 192 or 10 and doesn't require the router Port Forwarding setup. Advise when you got the local connection to work.
Get back with me on my questions and I'll google search the make and model of the router. Two key items that's goes into the Port Forwarding: The port number which is the same as the number you have in the ProScan Server Port box. The other item is to configure the Port Forwarding for TCP.
  #1095 (permalink)
Old 07-25-2013, 3:25 PM
nyair1's Avatar
What i am trying to do is set-up my home scanner that is running proscan and be able to listen to it at work over the proscan client software that you have. I'm not sure if i'm going about this the right way?? Do you have a setup guide to help me with that?
I will have have to check tonite when i get home on the make and model of my router. Thanks for the info so far guys.
Chris
Western NY
  #1096 (permalink)
Old 07-25-2013, 3:33 PM
ProScan's Avatar
Setup is in the help file. First determine if you want to use the Web Server which doesn't need a ProScan client, just a Web Browser or you want to go with the Remote Scanner Over IP feature which offers logging and recording capability. Setup of the Web Server and Remote Scanner Over IP is the same. Port forwarding setup is different for each type of router so I would consult with your router documentation on that.
  #1097 (permalink)
Old 07-26-2013, 2:58 PM
nyair1's Avatar
Now if i use the Proscan client software i would be able to have control of my scanner at home while im at work? I would like to able to do that if possible. Am i looking in the proscan help file or the client help files for set up? I will hopefuly have somemore freetime over this weekend to sit down and play with it more. I will have to dig around for my router instructions. I belive it is a Belkin model. Not sure of which one off hand. Thanks for the info.
Chris
Western NY
  #1098 (permalink)
Old 07-26-2013, 5:59 PM
ProScan's Avatar
The Client has more control then the Web Serber as you can download and upload. The Web Server has a virtual keypad control.
The ProScan file because you are setting up the server. The client doesn't have a server so it wouldn't be there.
  #1099 (permalink)
Old 07-31-2013, 8:51 PM
nyair1's Avatar
Ok now my home scanner is a bc780xlt. So i should use the "Remote scanner over IP" tab on the proscan software and follow those instructions to be able to have control of it from my work computer?
I have a Netgear N150 wireless router model #WNR1000 running off my Time Warner cable modem. I also have a Netgear universal wifi range extender model #WN2000RPT to extend the wireless in my house. I logged into the wireless router setup but i cant find anything for port forwarding? Thanks
Chris
Western NY
  #1100 (permalink)
Old 07-31-2013, 9:19 PM
lost_in_maine's Avatar
Did You get the Router from Time Warner?
Some ISP's Firmware disables the option to port forward..
Doug-BCD536HP HP-1 x2 BCD996XT
BCD396XT BCD-396T BC9000XLT
ST-2 x3 WBD-40 Discone Grove Scanner Beam
www.wirebridgeweather.com APRSWXNET http://www.findu.com/cgi-bin/wxpage.cgi?DW1694
Tags
bc785d with proscan 6.6, logging, proscan, sleep, windows
