Go Back   The RadioReference.com Forums > Computer Aided Monitoring and Programming > Scanner Programming Software
Scanner Programming Software - This is the place to discuss third party scanner programming and control software.
Old 02-01-2008, 8:44 PM
ProScan's Avatar
Post Official Software Thread
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
Old 02-01-2008, 10:52 PM
Wiki Admin Emeritus
Congrats Bob and good luck on the new release.
One suggestion for your web page; be sure to mention that a premium subscription to RR is required for the imports to work. The information can be pulled from our wiki, and the article can be linked to just like any other web page;
http://wiki.radioreference.com/index.php/Subscription
73s Mike
Old 02-03-2008, 11:15 AM
ProScan's Avatar
73s Mike
Ok. Oversight on my part as there was many things to do at release time.
Next version will include an UASD import/export feature for DMA and non DMA scanners that ProScan supports.
Bob
ProScan
Old 02-03-2008, 11:30 AM
FPO703's Avatar
Why not include the BCD396T as well since it's the same as the BCD996T?
Owner: Ohio_MARCS Yahoo Group
Equipment: PRO-96, BCD396T, BC246T, PRO-92, BC235XLT, BC245XLT, PRO-2016.
Old 02-03-2008, 11:33 AM
ProScan's Avatar
I will be adding the BC15 after the next release(in a month) then the BC996 after that.
Old 02-03-2008, 11:37 AM
ProScan's Avatar
Ok, I'll research the differences in the scanners and see what I can do.
Old 02-03-2008, 12:18 PM
Wiki Admin Emeritus
No not quite. The 396 doesn't support multi site trunking, nor does it do any of the GPS based scanning features. However, I would bet that the 396 (and perhaps the BCT15) have several common functions in the firmware, and that should make it easier for Bob, to be sure.
The BCT15 doesn't do digital at all, and has less channel capacity. Interesting how the 3 are similar in some ways, not in others.
73s Mike
Old 03-01-2008, 11:29 PM
mike_s104's Avatar
I'm waiting on Build 3 to see how the naming of the recordings are. I think it's what's I'm looking for. :-)
Old 03-02-2008, 10:50 AM
LordJ's Avatar
I'm waiting for someone to direct encode to mp3 or wma... Wow can't wait till build 3!!! I might take the plunge..
Just because I can, doesn't mean I will. (But I might)
Old 03-02-2008, 2:02 PM
splash1's Avatar
Hey Bob
How about adding the bc898t . Pro scan looks great might have to switch from trunk star pro.
Rick
Old 03-02-2008, 3:32 PM
ProScan's Avatar
It should be what you're looking for. If not then let me know.
Old 03-02-2008, 8:15 PM
ProScan's Avatar
Originally Posted by splash1
Hey Bob
Rick
I'm going to be doing just DMA type scanners from now on.
Old 03-02-2008, 8:18 PM
mike_s104's Avatar
Old 03-02-2008, 9:07 PM
ProScan's Avatar
Hey Bob
Rick
Sorry for the double post. i don't know how to delete this.
Old 03-06-2008, 11:06 AM
ProScan's Avatar
FYI - I'm in the process of changing my site to a new host and you may see it down until DNS servers get updated with the new host info.
Old 03-06-2008, 1:35 PM
Your site is working for me @ 1330hrs. Looks like a neat pgm.
I don't know if the newer GRE digital scanners are "DMA" or not so excuse this if they are not. If so do you plan to add support for them ?
Rob
Old 03-06-2008, 4:53 PM
ProScan's Avatar
Rob
No, Iím focusing exclusively on the Uniden products and will be adding the 15, 396, 246, and the 230 this year.
Old 03-06-2008, 6:12 PM
Thanks for the info.
Rob
Old 03-08-2008, 1:43 AM
ProScan's Avatar
Default ProScan Version 1.7 Build 3 Is Out!
I've added several items, many are user requested.
Import UASD files (all types) to ProScan (DMA and non-DMA scanner types)
Multiple sound cards support (capture)
Recorder user selectable filenames format
Recorder option lookup record flag from database
Recorder no loss
Quick Key assignment shows quick keys in use (DMA scanners)
Caption ICON user selectable
ProScan Sessions Manager
ProScan supports the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D Scanners. ProScan is feature rich with the friendliest user interface.
www.proscan.org
Bob
Old 03-09-2008, 5:40 PM
mike_s104's Avatar
Smile
Recorder use
Recorder no loss
www.proscan.org
Bob
Thanks Bob...
Build 3 names the files like I was looking for. (folders per each day would help organize, but I'm not complaining.) works beautifully!!
Tags
bc785d with proscan 6.6, logging, proscan, sleep, windows
