Old 02-07-2008, 03:40 AM
Default 996T connecting with Vista 64bit
Has anyone had any luck using the ARC996 Pro software connecting to the 996T from a computer running Vista 64bit? The softeware installs fine and runs fine it just won't connect. I'm 100% sure that its a problem with Vista 64bit not liking the USB cable due to lack of the proper drivers. I haven't found anyone , including Uniden that has 64bit drivers that work. Anyone have any suggestions? Oh, the computer in question is a laptop without a serial port.
Thansk,
Brad
Old 02-07-2008, 04:41 AM
Wiki Admin Emeritus
Brad did you check the USB manufacturer's website for drivers? I thought that would be the place to start. Or is it one of those generic brands? 73s Mike
Old 02-07-2008, 08:52 AM
Also I believe you have to run in admin mode?
Old 02-07-2008, 11:09 AM
UPMan's Avatar
Uniden Product Manager
We do have Vista 64-bit drivers on our web site for the USB-1 cable. I used the cable for about a year under Vista 64 (with the unsigned Windows XP 64 drivers) and other than having to do a special boot mode, it worked fine.
Got a question? Ask it in a public forum for faster response.
My Home Weather Station
Old 02-08-2008, 07:42 PM
When I first got the cable long ago the driver that was there didn't work. I downloaded the one that is there now and it worked like a charm! Thanks for the help!
Brad
Similar Threads
996T Max 256 Talkgroups S & S Problem W4UVV Uniden Scanners 6 05-09-2008 08:48 PM
Official BCD996T Post Release Thread scannerfreak Uniden Scanners 692 06-01-2007 10:59 AM
Connecting 996T to PC radio126 Uniden Scanners 2 03-19-2007 09:10 PM
Connecting GPS to the 996T question wesm1957 Uniden Scanners 1 11-24-2006 02:51 AM
Microsoft releases public beta of Vista Jeffn8wb Tavern Archives 14 06-12-2006 02:39 PM
