Old 02-10-2008, 08:07 PM
cpuerror's Avatar
Default FreeSCAN996 0.3 - Now with RR Import
This new version of FreeSCAN for the 996 & 15 scanners incorporates several improvements, the biggest of which is RR import for both trunked and conventional systems.
You can download it from http://scannow.org . FreeSCAN396 which supports the 246/330/396 scanners will also have RR import added on very shortly.
Old 02-10-2008, 08:28 PM
Wiki Admin
I'll make the changes in the wiki Thanx for letting us know Please announce when FreeScan396 has the RR import changes so it can be included in the web service support list. 73s Mike
Old 02-10-2008, 10:08 PM
cpuerror's Avatar
Thanks for covering the wiki for me. When i get the 396 version hammered out i'll post an update here as well.
Similar Threads
Win96 RR Import Problems JESSERABBIT Scanner Programming Software 13 09-16-2007 06:34 PM
BCD396T UASD import from RR jwwphoto Scanner Programming Software 2 05-03-2007 07:44 AM
ARC396 Import From RR Database swcscott Scanner Programming Software 1 03-19-2007 01:57 PM
Using ARC996 to import Australian RR frequencies okysmates Australia Radio Discussion Forums 3 02-01-2007 03:08 AM
LACMTA Rail Frequencies transitman California Radio Discussion Forum 3 12-26-2006 04:03 PM
