Old 02-11-2008, 11:21 PM
Question TrunkStar XLT & BCT8 Talkgroup Question
I've recently started using the demo of TrunkStar XLT with my BCT8 and am still working through the ins-and-outs of how the program operates. I've run into a minor annoyance and am hoping that someone can shed some light on what I might be doing wrong.
While in 'Radio Control' mode I'm picking up talkgroups that I don't want to listen to. They're auto stored in the 'User ID' fields so I select the 'Skip' option - but the radio keeps tuning into these groups.
Is there something that I have to do after I toggle the option from 'scan' to 'skip'? I've attached a screenshot if that helps to explain.
Thanks!
Old 02-12-2008, 08:31 AM
Wiki Admin
Really dumb question - did you upload the scan list to the scanner? It sounds like that hasn't been done - as long as you are in ID Scan mode, you should only see those TGs you've set up, and nothing else.
73s Mike
Old 02-12-2008, 10:01 AM
thecop's Avatar
If the screen shot is accurate, you are in the "Search" mode, which will stop on any transmission. I think you might want to select "Scan" mode, then the radio will only stop on those talk-groups you have selected.
Old 02-12-2008, 11:00 AM
Mike - I did upload the list to the scanner. (Or at least, I think I did)
Old 02-12-2008, 11:01 AM
Any idea how I get out of Search mode and get into Scan mode?
Old 02-12-2008, 11:23 AM
AH HA! Hitting 'Search' seems to have solved the issue! DOH!
Many thanks guys - I do appreciate it!
Similar Threads
Monroe Fire Talkgroup Question rdale Michigan Radio Discussion Forum 7 02-08-2005 07:54 PM
Sacramento County Trunk system talkgroup question Ben96cal Motorola Forum 1 10-02-2004 01:50 AM
Pro-96 Manual Talkgroup selection question bear105 General Scanning Forum 6 07-05-2004 09:41 PM
PRO-95 Talkgroup Question JML Trunking Forum 3 06-24-2004 06:18 PM
Baltimore Co Freq Talkgroup ID question dennyc716 Maryland Radio Discussion Forum 11 05-21-2004 05:08 PM
