Old 02-25-2008, 08:41 PM
Default Need help software to choose for pro84
Are there any late and great software for the pro 84 all I can find is the scanlite pro , arc83 and the pro83. Is there any differance in the firmware between the 83 and the 84?
Do you guys have an better idea then me on the ones i found? I could use some help the scanners I had were old and no pc connection. I'm all ears
thanks
Old 02-25-2008, 09:00 PM
Wiki Admin
I think that's about it for the PRO-84, which I think has the same firmware as the 83. Unless the freeware Load83 program has been modified, ARC83 has an edge in that it will import data from the RR database (though you should realize that since neither scanner is a trunktracker, it will likely import these kinds of freqs as conventional). You would need a paid subscription to perform the import, a topic that can be found on the front page of our wiki.
73s Mike
Old 03-01-2008, 02:21 PM
scanner92us's Avatar
Load83 will work with the pro-84.
Similar Threads
ARC 396 Pro Software tafkam Old Classifieds Archives 12 07-04-2008 04:19 PM
Uniden software vs. Arc396 scanrrman Uniden Scanners 9 01-21-2008 08:34 AM
BC246T Software dabigdog Uniden Scanners 8 12-08-2006 12:22 PM
BuTel software release first free software for Uniden BR330T! Butelsoftware Scanner Programming Software 0 11-03-2005 08:41 AM
FYI: BC796D SOFTWARE DEFICIENCY W4UVV Uniden Scanners 0 11-10-2004 11:57 AM
