Old 02-29-2008, 12:05 AM
Default UniTrunker
2 questions,
1, will it work on conventional frequencies/systems as well?
2, will you hear the audio also or is it just visual
Old 02-29-2008, 12:37 AM
OH/WV DB Admin
Send a message via MSN to mtindor
Originally Posted by _Jerry_
2 questions,
A1: No, it is not for conventional frequencies - purely trunked systems
A2: That depends on what you mean
Unitrunker can control your scanner - in fact you can have two scanners in use, one with a discriminator tap or data that feeds control channel info in, and then another scanner that Unitrunker can control (it has to be one that it supports) which it will tune to the appropriate voice frequency.
If you have just one scanner/reciever, then you can set your scanner up so that it switches to the audio channel and plays the audio when a talkgroup is active, but during that time Unitrunker won't be listening to the control channel and will not update its display with that information. When the talk group is no longer active and the scanner switches back to the control channel for listening, Unitrunker's display will update with current data again.
Unitrunker is not meant to be a 'control program' for your scanner per se. It is meant to analyze trunking data and present it in a meaningful way so that you can know more about the trunked system and its users.
Similar Threads
Configuring UniTrunker using GRE PSR 600 tbogs Trunking Control Channel Decoding 17 12-15-2008 02:27 AM
UniTrunker and Re-Banding KT7L Utah Radio Discussion Forum 42 06-18-2008 04:17 PM
Layman terms Jono40141 Trunking Control Channel Decoding 9 01-26-2008 01:25 AM
UniScope Images for UniTrunker Troubles William Trunking Control Channel Decoding 13 01-03-2008 07:02 PM
Unitrunker - and SYS ID 5A3E FLANO Trunking Control Channel Decoding 7 09-28-2006 02:08 PM
