Old 03-06-2008, 04:45 PM
Default importing trunked systems into software from rr.com
I am using trial psredit500 & arc500 software to decide which I will use with my gre psr-500. When connected to rr.com to import a trunked system what import option should be used *primary cc's only* *primary & alts only* *all site freqs* ? should I use *all site freqs* so everything will be covered or will this slow scanning down?
Old 03-07-2008, 12:24 PM
As a general rule, I use "all frequencies" if they will fit into the TSYS definition to avoid missing control channels which aren't flagged in the RR database. Otherwise, I'll use "primary CCs and Alt" followed by "primary CCs only".
I don't think it slows anything but the initial CC acquisition to have all the frequencies in the TSYS. I know having all frequencies present saved me a couple of times on my Pro-96 because the database hasn't always had accurate CC information on some systems.
Mark J.
Old 03-08-2008, 09:26 AM
Mark J.
I'll be importing them all then. Thanks for your answer Mark.
Similar Threads
Pro 97....multiple trunked systems on a particular bank? wannabescannist Radio Shack Scanners 8 02-26-2007 05:04 PM
Buffalo NY Trunked Systems ? Saint New York Radio Discussion Forum 19 12-16-2006 03:25 PM
Trunked Systems n' Repeater Input Freqs? Dave_D General Scanning Forum 14 08-02-2006 11:51 AM
An ARC996 software record? W4UVV Uniden Scanners 3 07-31-2006 05:20 AM
Band Opening - Unknown trunked radio systems brian North Carolina Radio Discussion Forum 7 07-23-2006 04:36 PM
