Problem with BuTel ARC500 Software
HI, I'm having some problems with the BuTel ARC-500. When I upload some Conventional Objects the Frequency's and Alpha Tag's are there but when I hit the scan key it shows "nothing enabled" on the Scanner. I did mark scan list 1 on the ARC-500 Software I also used the Global Settings on the PSR-500 and Enabled Scan list 1 but it still will not scan. Any help would be appreciated
