Old 03-07-2008, 06:21 PM
btritch's Avatar
Send a message via MSN to btritch Send a message via Yahoo to btritch
Arrow WIN 97/PRO 97 Problem
I have a problem with my pro 97 win 97 software. I have trunking LTR banks saved in the scanner that I have found by searching and when I open win97 to edit things on it it tells me that 0-02-002 etc. is not a valid format it must be in the A-AA-AAA or AAAAAA format..I have tried both ways and neither way will accept it, If there is no way edit it in the software with it and I erase them from the software, How Can I get them back, What should I do... I posted in the Radio Shack Scanner Forum and They sent me here because we thought it was a software glitch.. What should I do to fix it?
Thanks!
Brian
Paragould/Greene County Arkansas 72450
Online Area Scanner Feed: http://greene.ar.scanamerica.us/
Old 03-07-2008, 06:51 PM
emscapt9816's Avatar
Lightbulb Win97 Question
I just started messing around with an LTR system on my PRO-2055 using Win97. I suggest you check all the settings as follows;
1. On the "Channels" Tab, make sure "Type" is set to LTR.
2. Make sure your frequencies are correct and in order, in the right channels.
3. Under "Rx Mode", those frequencies should be "LTR".
4. On the trunk side of the page, make sure the "DEC" button is selected.
5. Under the "ID" tab, make sure your UID follows proper format, which yours seems to, AND, (and this has happened to me,) make sure you don't have any "invisible spaces". By that I mean, make sure you didn't accidently hit the space bar before, within, or after the UID.
6. Make sure your frequncy entries don't have those spaces either.
I can't tell you how much time I wasted on ALL conventional and trunked systems because of setting errors or (most annoying) typing errors. Good Luck!
Eric
FDNY*EMS Captain
Citywide Dispatch Supervisor
KC2SDZ
WQKB645
Old 03-07-2008, 06:54 PM
Default Ltr
Thanks!
I hit this in programming manually.
The talkgroup trunking type must be set to LTR. And manually the Pro-97 doesn't want the dashes in the TGID.
Also I've seen an LTR system where it sends the cwid on TGID 0-07-255 and all other channels (0-0x-255) the Pro-97 will not allow a 255 setting for the end number.
Old 03-07-2008, 07:21 PM
btritch's Avatar
Post Ltr
So how should I fix that?
Brian
Old 03-07-2008, 07:25 PM
btritch's Avatar
I took the 03-03-255, 05-05-255 and 07-07-255 groups out and it accepted the others, however, these are the main three.. What will I have to do? Go back and add those in when they key up again?
Brian
Old 03-07-2008, 07:50 PM
N1BHH's Avatar
Send a message via AIM to N1BHH Send a message via MSN to N1BHH Send a message via Yahoo to N1BHH Send a message via Skype™ to N1BHH
LTR systems don't have talk groups higher than 253, 254 and 255 as the last three digits. Usually a 253, 254 or 255 are for the morse code identifier. I don't put them in. I think that the software is designed to reject that talk group out of hand. All the morse identifier does is send the call sign of the system.
WQBX787 = GMRS
Pro2055 Pro94A Pro2006 Pro2015 Pro2021 Pro164
Yaesu FT-60R, 8000R & 8800R, Motorola MTX9250, Alinco DR635T
Old 03-07-2008, 08:27 PM
btritch's Avatar
And most of the time when the clicking is going on (about every 4seconds or so) this is the three that pop up or when the morse code goes across the system this is the one that pops up. Now I know why this is.. Wonder why they do that anyway? Anyways, it's accepting them as long as I leave those off.. Thanks For The Help All!!
Brian
Old 03-10-2008, 10:05 AM
N1BHH's Avatar
Read up on LTR here: http://wiki.radioreference.com/index.php/LTR
Actually only goes to 254 for group numbers.
WQBX787 = GMRS
Old 03-10-2008, 11:52 AM
Default 255
Originally Posted by N1BHH
Usually a 253, 254 or 255 are for the morse code identifier. I don't put them in. All the morse identifier does is send the call sign of the system.
Folks- don't underestimate the information that's contained in the ID! With that ID you can look up the info on the FCC database and learn a great deal about the system such as possible additional channels, location of the transmitters and other systems the same company might own/operate. (But of course you won't want to listen to it after you know what it's saying.)
(Knowing morse has proven handy for me in lots of ways throughout my life. From reading blinking light signals on Navy ships to verifying nav aid ids while flying light aircraft, to being able to use radio system id for further research. Code has been very good for me!)
Old 03-10-2008, 02:03 PM
bubbaearle's Avatar
Can you elaborate on that......If btritch gave ya an ID could you teach us how to look it up in the FCC database?
Bubbaearle
Pro 62
Pro 83
Pro 97
GRE 500
BC 350C
Old 03-10-2008, 03:17 PM
N1BHH's Avatar
http://www.fcc.gov/searchtools.html
WQBX787 = GMRS
Old 03-10-2008, 08:11 PM
bubbaearle's Avatar
Question
Where from there do I go to search for system info with just a TGID?
I understand how to search the FCC Database........no stanger to that.......
Just never came across the function to search out system info with only a TGID.
Bubbaearle
Pro 62
Pro 83
Pro 97
GRE 500
BC 350C
Old 03-10-2008, 11:34 PM
n2mdk's Avatar
I think they are talking about the System ID a TGID has no meaning outside of the system. The Ames and ISU systems have TGIDs that are the same.
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
Grundig Satellit 700
Old 03-11-2008, 05:50 PM
bubbaearle's Avatar
I was hoping to learn something new.........
Bubbaearle
Pro 62
Pro 83
Pro 97
GRE 500
BC 350C
Old 03-11-2008, 06:22 PM
Default ID vs TGID
The discussion seems confused between the two.
The ID I was referring to was the FCC Callsign (Station identifier) which is often sent in morse code. The system I'm working on currently sends: WNWJ207 in code.
A talkgroup ID is an arbitrary assignment by the system administrator. Blocks of TGIDs may be assigned to departments. This is of no interest or involvement by the FCC so they have nothing of use in their database.
Old 03-11-2008, 06:23 PM
Default Something new
Well, you *could* learn Morse Code........ :-)
Similar Threads
Pro 97 Interesting Problem lexxtank Radio Shack Scanners 4 07-19-2007 01:54 AM
Win 97 Glitch brey1234 Radio Shack Scanners 2 07-12-2007 10:13 AM
Pro 97 Power Problem spitnsand Radio Shack Scanners 4 05-29-2007 11:13 PM
Can't transfer 97 files or frqs to 92 gs_new Western Canada Radio Discussion Forum 6 04-10-2007 09:04 PM
Pro 92 with Win 92 help gs_new Radio Shack Scanners 3 04-06-2007 02:43 AM
