Old 03-12-2008, 11:01 PM
KC9GLG's Avatar
Default Using two usb-1 cables?
Is it possible to use two USB-1 cables at the same time? Or would there be a problem with the Driver? I have a BR330t and a BCD396t and would like to run two different software programs at the same time. I've got Vista.
Old 03-12-2008, 11:44 PM
GreatLakes's Avatar
I haven't actually done it, but in theory it should work. The driver should assign different COM ports to each.
Old 03-12-2008, 11:54 PM
I've used ARC330 & ARC396 Pro simultaneously to run my 330 and 396 on windows Xp with no problems ,as mentioned make sure you have different com ports assigned for each program.
Old 03-13-2008, 04:46 AM
slkrueck's Avatar
Different com ports will be assigned. I'm running ARC396 & ARC898 on my Vista.
Scott
Pro-2040
Pro-2046
BCD396T
BC898T
BC60XLT-1
Kaito 1103
Similar Threads
RADIOSHACK USB Scanner Programming Cable and Software 7586 Old Classifieds Archives 14 02-21-2009 12:25 AM
BC 296D USB to USB Cable acosell Uniden Scanners 4 11-06-2007 10:57 AM
HF Ute Monitoring - patience is needed! mtindor HF/MW/LW General Discussion 4 03-16-2007 01:41 PM
Civil Air Patrol bodnarp Aircraft Monitoring Forum 11 06-02-2006 07:42 PM
Motorola Smart Rib RLN1015C W/ aftermarket cables 2wayguru Old Classifieds Archives 2 04-27-2005 03:55 PM
