Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Antennas and Associated Hardware > Scanner / Receiver Antennas
Scanner / Receiver Antennas - For discussion of any type of receiving antenna used by a scanner or receiver base, mobile or handheld.
Old 06-08-2008, 9:38 PM
Default RS 102" CB whip antenna for Shortwave?
Has anybody used this #21-903 antenna for Shortwave?
http://www.radioshack.com/sm-102-sta...i-2102428.html
I made a test setup by driving a 3 foot pole into the ground in my back yard and attached this antenna to it (it was meant to be hooked to a Pick up truck. ) and got fair results on my SW receiver.
I was wondering anybody else had tried this?
thanks
Old 06-08-2008, 9:43 PM
My guess is it would do real well in the 26-27 Mhz range.
"Now we've been every place between here and South Sioux
And we've seen us a truck-stop waitress or two
But this gal's built like a burlap bag full of bobcats:
She's got it together"
Old 06-08-2008, 10:09 PM
Actually, I tried that and I picked up a few of the HF beacons at 28.200.
Old 06-09-2008, 7:29 AM
Its a hunk of metal in the air it will work. not great but will work.
Old 06-09-2008, 7:50 AM
jhooten's Avatar
The Navy did a study of recieving antennas. They determined you could pick up a useable signal on a 9 foot antenna as low a 2 megahertz.
As emr said it will work but not all that great.
Jerry
I read it on the internet, so it must be true.
Old 06-09-2008, 3:12 PM
HF HF is offline
Default 102"
Hello good buddy...got a sloppy copy on me ?
I use a R75 + a 102" whip w/ a radial wire 102" long. The mirror mount is bolted to a 20 foot mast ( had to duct tape the mast where the mirror mount bolted onto), so I basically have a vertical dipole. It works excellently on 26-28 MHz of course, 14 MHz takes 2nd prize. But all bands seem to be coming in good.
When a thunderstorm comes my way, I disconnect the antenna and use just a vertical 48 inch wire (seems to work almost as well inside for 26-28 as the 102" 20 feet up does outside !?! Just some thoughts.
take care.
Jason
Triple 6 Ontario Canada
Sony ICF-2010
Icom PCR100
Wellbrook Loop
102" Whip
Old 06-09-2008, 4:12 PM
take care.
Jason
that was what I was thinking when I hooked my SW receiver to it. I know very little about antennas, but It didn't seem like their was anything magical about a 10 meter ham antenna vs. this 102 inch wire whip. I was able to pick up New Zealand and Kiev with it in June with all the thunderstorms between here and there in the daytime. I was thinking about mounting / welding some radials on the mirror base plate, but since it grounds out to the mast, perhaps they aren't nessessary? I wanted to get it set before I put it on my roof. right now its mounted to a 36 inch steel pipe pounded into the ground. I checked a few of the HF Beacon listening posts around on the web and this antenna doesn't seem to be doing any worse than some of those that are configured for 20 meter and 10 meter. (at least now when propagation isn't the best)
thanks
Old 06-09-2008, 5:15 PM
RESCUE4NFD's Avatar
I remember the "Good Old Days" when anything with a 2 WAY-RADIO had a WHIP.....
RESCUE4NFD
Mike in Garland,Tx.
www.Careflite.org
Old 06-09-2008, 7:13 PM
kb2vxa's Avatar
Whip 'em and club 'em, then slap the cuffs on 'em! Who needs a Taser when you have a radio?
Old 06-09-2008, 7:26 PM
ridgescan's Avatar
It's been my experience that a shortwave radio is perfectly happy with pretty much any antenna as long as it's ouside and has a decent ground. I have two SW's in op-one runs off a centerload "trucker type" CB whip. The other which works quite well is a 900 MHZ "christmas tree" yagi poined straight up to the sky (a little trial and error discovery)<<I'd LOVE to hear what some of you technical wizards say about that one
Old 06-09-2008, 9:04 PM
Buddy of mine uses a 102 inch steel whip mounted on his SUV bumper as a SW antenna, and gets surprisingly satisfactory results. Of course, he has an automatic antenna tuner installed inline, which makes a significant difference. Not sure I'd be comfortable trying to transmit SW on a 27mhz antenna without an antenna tuner. I'd like to try it with a base loaded whip, myself. Hole mounted on a large vehicle roof, I'm betting I could do as well as I want to.
"Man up and drill those holes!"
Old 06-09-2008, 9:45 PM
Does an antenna tuner help if you are only receiving?
Old 06-09-2008, 10:40 PM
ridgescan's Avatar
When you say SW antenna do you mean "ham" or does he actually SW-DX from his mobile?
Old 06-10-2008, 12:15 AM
Yes, to some extent. But it is mostly used for matching the impedance of a broadband antenna to a transmitter to optimise signal and power transmission. Not really sure how much of a difference it makes simply for receiving, as I have no experience with that. And I believe it is a different kind of antenna tuner unit that is utilised strictly for receivers, as they would have to be manual. The auto tuner tunes only when you press the transmit button, improving performance for both transmission and reception, but obviously would do nothing if you didn't transmit.
It's a CB antenna hooked up to an HF Ham transceiver. He transmits and receives HF through it.
Old 06-10-2008, 1:04 AM
andrewccm's Avatar
I need to just get my antenna outside somehow.. After my experiment tonight taking my E1 outside with AN-LP1, I am convinced that this is the only approach that is going to work for me... Inside anywhere in my house is like listening to white noise for all but the strongest signals.
Now I just have to figure out how to neatly run something out to the backyard from my upstairs and that the HOA will not see... hrmm... LOL
AndrewCCM
Crystal Clear Media
BCD396T, BCT15, PRO-2026, PRO-2046, Kenwood TK840, Eton E1XM, ST2, Wilson 800 Yagi, CM Rotator, iPhone with Scanner911 and Action Scanner
Old 06-10-2008, 4:32 AM
rcvmo's Avatar
This claim is absolutley correct.
Many moons ago when DPD, DFD had the old Ded reckoning AVL, we used a VHF whip and an antenna tuner to recieve the 1.7 MHz beacon off Belle isle.,
Many moons means not that long ago. Late 90's is when the system was decomissioned. In the mid 80's I could hear the beacon all the way into the UP!!
rcvmo
Old 06-10-2008, 5:16 AM
k9rzz's Avatar
I'll use my mobile whips for SWBC Dxing and they work well. For 3485khz, my 20 meter hamstick works better than my 75m hamstick (no tuner). You'll hear plenty of HF stuff with that CB whip if the receiver is relatively sensitive (what radio do you use??).
Old 06-10-2008, 7:25 AM
I boughta used Radio Shack DX394. Its not bad for a $120 base receiver.
Old 06-10-2008, 7:15 PM
Have you tried just streching out a long wire to the shortwave radio.. Maybe even attaching the long wire to a steel fence.. You would be surprised by the difference, versus a ham stick or 102" whip.
Old 06-10-2008, 11:49 PM
I've got a chain link fence. So attaching a wire to it will work?
