IndyEmsGuy
I am looking to get a better antenna than the RS800 that I have on my GRE PSR-500. There are a couple of digital systems I want to pick up and the towers aren't very far away but I am having some trouble getting them to come in clearly. They are digital trunking systems both in the 850-860mhz range. I have been looking at two different Yagi antennas (see links below). Currently I live in an apartment and will have to keep the antenna inside or possibly the attic as I'm on the seconde floor and have attic access. So I would like some help from people with experience and that know a lot more than I do about which antenna they think I should get or if there is even a better one than the two I have here. Thanks for you help!!!
YG-2819: http://www.universal-radio.com/catalog/misc/4810.html
Y8066: http://www.scannermaster.com/Y8066_Yagi_Base_Antenna_p/07-540705.htm
Here are some others I have been looking at as well:
http://www.wpsantennas.com/301111-wilsoncellularyagi806mhz-940mhzcellphoneantenna.aspx
http://www.wpsantennas.com/408-yb-d...agicellular824mhz-894mhzcellphoneantenna.aspx
17dBi Gain! http://www.wpsantennas.com/y80618-a...d806-896mhz18elementyagicellphoneantenna.aspx
14dBi Gain!! http://www.wpsantennas.com/y80612-a...d806-896mhz12elementyagicellphoneantenna.aspx
