is it possible to switch from a rs magnet base to a permanent fender mount base with the antenna included with the rs magnet mount antenna system? thanks
So your wanting to use a NMO mount but the RS scanner whip? Try one of these and take out the plain whip and grind down the scanner whip at the bottom to fit. but i don't thing the antenna would be strong enought to hold up. or you might drill the hole bigger to accommodate the RS whip. I have the 2nd one listed here. http://www.theantennafarm.com/catal...roduct_info&cPath=191_192_206&products_id=764
