I just got my SRH519 but they sent the RH519 on mistake. i tested it before i send it back and it is worse then the stock duck from the VX7R and no better then a RS scanner duck. I tested it on the WX band to see how it will do for the RR band. I listen to trains so i want to make sure it's good for there as well as the 150mhz and 450mhz. plus i want to be able to transmit the ham bands as well. I'm using it on my FT60R. what other brands or models makes ducks that are better then this? I have the RH77CA but want a shorter one as well.
I once had a comet triband version that was 2m 70cm and the GHZ band. but it was this pathetic too. i think those skinny ducks don't work as well as the fat ones.
Eric Burris kc0ldt
Eric Burris kc0ldt
