IndyEmsGuy
I am using a PSR500 to monitor two different P25 digital systems. One system is simulcast and most of the time all i get is garbled radio transmission. Reading posts and talking to others looks like I need to get a Yagi antenna. I live in an apartment and I am not allowed to mount any antennas outside. I have no windows that face the direction of the simulcast tower. Will a Yagi work inside pointed in the direction of the tower? I am not sure if the walls and everything else would block the signal. Also since I listen to two different systems if the yagi is pointed at the simulcast tower I probably wouldn't be able to pick up the other system, is this correct? The other system has a tower about 5 miles south of the simulcast one if I point the yagi between them would I be able to pick up anything? I would like some guidance on the best solution. Thanks!!!
