Would it help to spray paint the following antenna black since I read that black helps absorb signal better?
http://www.radioshack.com/product/index.jsp?productId=2103641
I have that antenna...the only thing that would help it, is leave it at the store... Get a real antenna.. unless you're REAL close to the transmitter location...
I don't know what you're trying to listen to but for it has been outstanding. It's not worth a damn for 800 but that's not what it's meant for. It's works great from Vhf air through Uhf.
Regular black paint is a good absorder in the visible electromagnetic spectrum. It doesn't absorb the RF spectrum the same way since the wavelength is much longer. The black paint used on some aircraft is loaded with other compounds to scatter radar waves.
Bob
There is no paint that will scatter radar waves to any extent or have any noticeable effect to RF bouncing off a surface.
You sure?
How do they work so well at lightwave frequencies?
I worked in an area that tested things like we are discussing. A simple coating of loaded paint will not reduce a radar cross section enough to evade anything. I don't deal with lightwaves but if you think about it, light is a much shorter wavelength and the texture of some paints looks pretty large in comparixon.
prcguy
- black absorbs HEAT better concerning signal? i don't think so....black helps absorb signal better?
